Hurst Super Shifter 3? #1464414
07/07/13 10:58 PM
07/07/13 10:58 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Hey guys, I'm gonna make an attempt to try to attach a picture. Is this the bracket you guys are using for this shifter? How much work is it to get to use this shifter? Anyways looking for some ideas when I get ready to install it.
Thanks!
Zak
Re: Hurst Super Shifter 3? [Re: Z_Z] #1464415
07/07/13 11:05 PM
07/07/13 11:05 PM
Out of the State of Confusion
blue_stocker Offline
That looks like a bracket Hurst made in the 60s-70s for the comp plus shifter into 62-65 B-body cars. It took long rods and wasn't the best piece Hurst made.
Re: Hurst Super Shifter 3? [Re: Z_Z] #1464416
07/07/13 11:10 PM
07/07/13 11:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well first you need to find or make the linkage for that mounting bracket. I have seen them on Ebay before direct from Hurst. What body are you going to use it in?
Gus
64 Plymouth Savoy
Dana 60
Re: Hurst Super Shifter 3? [Re: fourgearsavoy] #1464417
07/07/13 11:15 PM
07/07/13 11:15 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
69 b body..I was thinking about making my own rods?
Re: Hurst Super Shifter 3? [Re: Z_Z] #1464418
07/07/13 11:18 PM
07/07/13 11:18 PM
Rittman Ohio
Rittman Ohio
There is a kit on ebay right now it looks like this
64 Plymouth Savoy
Dana 60
Re: Hurst Super Shifter 3? [Re: Z_Z] #1464419
07/07/13 11:41 PM
07/07/13 11:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The one I had back years ago had a solid plate that
mounted the shifter.. not some sheet metal ... the
rods on that look thin... mine had 3/8" rods with 1/2"
sleeves over the rods.. very beefy and worked great
EDIT
I think mine was just called a super shifter.. not a 3
so maybe they got cheap over the years
Re: Hurst Super Shifter 3? [Re: MR_P_BODY] #1464420
07/08/13 01:21 AM
07/08/13 01:21 AM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Alright cool, gives me some ideas..I've heard it will require some cutting to make this work, which looks like it will set back some?
Re: Hurst Super Shifter 3? [Re: fourgearsavoy] #1464421
07/08/13 02:09 AM
07/08/13 02:09 AM
Cascade, CO
reknapp52 Online content
reknapp52  Online Content
Cascade, CO
I had 2 super shifters back in the 70s, the brackets looked exactly like the ones in the picture from Ebay. The purpose of the bracket was to raise the shifter to improve the geometry between shift rods and shifter arms.
Re: Hurst Super Shifter 3? [Re: reknapp52] #1464422
07/08/13 03:28 AM
07/08/13 03:28 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I use the super shifter 3 but with stock mounting plate and homemade rods. Work really good.
Re: Hurst Super Shifter 3? [Re: blue_stocker] #1464423
07/08/13 08:59 AM
07/08/13 08:59 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Essentially mounts the shifter in what would be a stock location for an a body, for a straighter throw. Seen them used on later (68, 69) B bodies, too. Requires some cutting of the floor tunnel on a B body. Try A body shift rods with this set up...
Re: Hurst Super Shifter 3? [Re: Sixpak] #1464424
07/08/13 09:28 AM
07/08/13 09:28 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Those are the rods you need. Can't tell by the pics if the keys are correct. The biggest problem you will find is keeping that whole mess from rattling loose. I'm still fighting mine.
Re: Hurst Super Shifter 3? [Re: Bill MeLater] #1464425
07/08/13 01:15 PM
07/08/13 01:15 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
if you didn't have the square top 4 speed A-body tunnel, you were hacking up the tunnel to fit. Super Shifter 3 has a seperate stick for reverse, and straight rods for the forward gears. Mine had heim joints on it, fun to row that shifter, only thing quick was a Verti-Gate.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Hurst Super Shifter 3? [Re: Slingshot383] #1464426
07/08/13 10:17 PM
07/08/13 10:17 PM
western iowa
Z
Z_Z Offline OP
Z_Z  Offline OP
Z
western iowa
Thanks for the post guys, the plan was to see what this mounting plate looked liked and buy some heim ends and rods from speedway, and go from their. Maybe I'll see what the stock shifter plate looks also.
Re: Hurst Super Shifter 3? [Re: Z_Z] #1464427
07/08/13 10:38 PM
07/08/13 10:38 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
make your own Zak...use Heim joints ...thread the rods and bolt the joints to the selectors....
