Steering Stabilizer #1464209
07/07/13 07:32 PM
07/07/13 07:32 PM
Wausau,Wisconsin
Kilrbee Offline OP
Kilrbee  Offline OP
Wausau,Wisconsin
I have a 92 Ram W150 I put a set of 31 x 10.5 x 15's on the truck, and now it seems to wander going down the road. I am wondering if anyone has any experience with a steering stabilizer or will it help or not?
Re: Steering Stabilizer [Re: Kilrbee] #1464210
07/07/13 08:46 PM
07/07/13 08:46 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
it will slow the wander down a bit. did you raise the truck? are these tires significantly taller than the old ones? might be time for an alignment.
Re: Steering Stabilizer [Re: Kilrbee] #1464211
07/07/13 08:57 PM
07/07/13 08:57 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Bigger tires on a truck like that need to see more toe-in. And since toe - in is about all you can adjust, make sure it has 3/16" or so. I had to set all my old power wagons like that but then I was using a bit bigger tire than you are.
Re: Steering Stabilizer [Re: superwrench] #1464212
07/07/13 09:49 PM
07/07/13 09:49 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Also consider adding a u-joint style steering shaft from the gear box to column. The wider tires will really tax an already poorly designed system with the aluminium bell.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Steering Stabilizer [Re: hp383] #1464213
07/07/13 10:37 PM
07/07/13 10:37 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
31s came stock. He probably only jumped up from a 235/75. I suggest you check balljoints and tie rod ends aswell
Re: Steering Stabilizer [Re: 76dodgeboy] #1464214
07/07/13 10:46 PM
07/07/13 10:46 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
A stabilizer can mask problems also.
I am truckless..
Re: Steering Stabilizer [Re: 76dodgeboy] #1464215
07/08/13 07:47 PM
07/08/13 07:47 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
I know this. But the original design was not good for any of the stock or larger tire sizes. The bell just wears out and you will wander all over. The wider tire will also want to pull into the grooves more so than a narrower tire.
