Re: oil filters
[Re: BradH]
#1463886
07/07/13 11:56 AM
07/07/13 11:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've heard good things about WIX, too. Don't they offer standard and "race" versions of their filters, too? Any idea what the differences between those are?
Yes they do.. the "R" race filter has less filtering to allow more flow and has the by-pass set differently.. I dont usually use the R filter... I've never had a pressure drop with the standard filter ![](/ubbthreads/images/graemlins/wave.gif)
Re: oil filters
[Re: MR_P_BODY]
#1463887
07/07/13 12:08 PM
07/07/13 12:08 PM
Posts: 167 mi
dirty magnum
mi
the jomar have no bypass , they work good at the track but on a long drive on the street oil preasure seems to go crazy. I was wondering if anyone else noticed that?
Re: oil filters
[Re: dirty magnum]
#1463889
07/07/13 12:53 PM
07/07/13 12:53 PM
MR_P_BODY
I've never run that one but what do you mean the pressure goes crazy ![](/ubbthreads/images/graemlins/wave.gif)
Re: oil filters
[Re: Deepockets]
#1463893
07/07/13 03:38 PM
07/07/13 03:38 PM
Posts: 167 mi
dirty magnum
mi
if the "r" or racing filter has a stronger canister, use it. here's a picture of what happened to the standard. I had adjusted the pressure relief a little too much and it went over 100 psi on start up. the canister grew and lost the sealing tension for the gasket.
wow ,
Re: oil filters
[Re: Just-a-dart]
#1463896
07/07/13 04:59 PM
07/07/13 04:59 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
I like the one on the left it holds more oil and lubricates t he engine compartment
thanks rod, maybe I can fill it with silicone! where's shilo when you need him.
Re: oil filters
[Re: Just-a-dart]
#1463897
07/07/13 05:18 PM
07/07/13 05:18 PM
MR_P_BODY
I like the one on the left it holds more oil and lubricates the engine compartment
I did that same thing a week or so ago.. jack up the oil pressure tooo much and lubed everything... should be good from rusting for a while ![](/ubbthreads/images/graemlins/wave.gif)
Re: oil filters
[Re: dirty magnum]
#1463899
07/07/13 09:06 PM
07/07/13 09:06 PM
MR_P_BODY
how are you jacking up oil preasure ? different spring?
I put a shim in there but when I put the cap back in I didnt see I pushed it in farther and it stayed there.. it gave me about 120 psi at idle and lasted about 1 minute then popped the O-ring out... over all the spring was about 1/4" shorter to give me that much.. doesnt take much to raise the pressure... it was suppose to be about .030 ![](/ubbthreads/images/graemlins/wave.gif)
