Which head gaskets for magnum 360 #1463315
07/05/13 09:58 PM
07/05/13 09:58 PM
ERIE PA home of the RENCH MOB
mike_vango Offline OP
I just did some upgrades on my engine and need new head gaskets.
It is a stock bore 9:1 360 magnum with reworked stock heads. I was thinking I should get the replacement gaskets that would of came on the 360/380 crate motor but couldn't find the part number. Any other suggestions with part numbers so I can check them out.
Re: Which head gaskets for magnum 360 [Re: mike_vango] #1463316
07/05/13 10:14 PM
07/05/13 10:14 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
mancini has mopar performance head gaskets for magnum.also having sale thru july7
Re: Which head gaskets for magnum 360 [Re: mike_vango] #1463317
07/05/13 10:27 PM
07/05/13 10:27 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Most auto parts carry the magnum head gaskets, made by felpro you can look them up online. If you want a bit more comp you could do the thinner MP head gaskets or Mr.gasket units.
Re: Which head gaskets for magnum 360 [Re: goldmember] #1463318
07/05/13 10:31 PM
07/05/13 10:31 PM
I think I found them.
Re: Which head gaskets for magnum 360 [Re: mike_vango] #1463319
07/06/13 12:32 AM
07/06/13 12:32 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
that's cool,I just go down the block and pick those up a Advance auto parts.
