70 cuda dashpad #1462966
07/04/13 11:20 PM
07/04/13 11:20 PM
Abilene Tx
superbird21 Offline OP
Abilene Tx
thinking about getting a dash pad with a plastic core,any feedback? the only reason im considering a plastic core is because i dont have a good core to send in.Ive always in the past gotten the steel core ones.Any feedback would be appreciated Thanks ALAN
Re: 70 cuda dashpad [Re: superbird21] #1462967
07/04/13 11:40 PM
07/04/13 11:40 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
rumor has it that it warps in time
Re: 70 cuda dashpad [Re: superbird21] #1462968
07/05/13 02:40 PM
07/05/13 02:40 PM
SE VA
hemibee69 Offline
hemibee69  Offline
SE VA
I have one that has been in the car for more than 6 years. It definately shows signs of warping. If you look closely you can tell where the studs bolt it to the dash. It is not bad enough for me to go thru the hassle and expense of swapping it out. My other e body had the dash redone by just dashes. about double the price but for a 70 Challenger it was/is still spot on. I do not know about the newer fiberglasss core pads but the older one I have did not hold up as well as I wanted.
JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly)
1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph
1970 Challenger SE 383 4 bbl A/C PB PS Leather
1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: 70 cuda dashpad [Re: superbird21] #1462969
07/06/13 12:05 AM
07/06/13 12:05 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Don't be tempted using the plastic core...Use the metal core...
