Re: Ladder bar cars ?
[Re: griff70440]
#1462836
07/04/13 04:07 PM
07/04/13 04:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is 7s fast enough.. I was low 9s with ladder bars in my old chassis but I changed over to a 4-link.. my car was violent with ladder bars.. but I put ladder bars in my Rampage... but I only want 10.0s in that car
[Re: griff70440]
#1462839
07/04/13 08:07 PM
07/04/13 08:07 PM
MR_P_BODY
I would like to go mid to high 8's in a 2800 lb duster
I would go with a 4-link over the ladder bars.. way less violent and can handle all types of track conditions .. JMO
[Re: griff70440]
#1462841
07/04/13 08:47 PM
07/04/13 08:47 PM
MR_P_BODY
The car I'm buying has ladder bars and a tube coil over front. I'm thinking a BB. I have a Lenco I'd like to put behind it. The car weighs 2800 lbs with a SB in it.
I'll sell you my car.. it weighs 2400 with in in it turn key with my W-9.. runs high 8s with the mild cam.. 4-link and strut front end
[Re: MR_P_BODY]
#1462842
07/04/13 11:05 PM
07/04/13 11:05 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
my dart has ladder bars, hooks on any track without any work and runs 8ohs. Go for it you will be fine.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: MR_P_BODY]
#1462843
07/04/13 11:11 PM
07/04/13 11:11 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Can you explain the word "violent" a little more...?? How/when was the car violent?
[Re: Jeepmon]
#1462844
07/04/13 11:27 PM
07/04/13 11:27 PM
MR_P_BODY
Sure.. it hits the tires so hard it was like someone punched me in the chest HARD.. that was on a 1.22 60'... with the 4-link in the car its smooth and I get a 1.19 60'
[Re: 1967dartgt]
#1462846
07/05/13 12:38 AM
07/05/13 12:38 AM
MR_P_BODY
Same shock?
Yeah... QA1.. I had them all over on the adjustment.. the only thing that would calm it down was lower launch rpm with more tire pressure... then it was 1.24-1.25 60'
[Re: MR_P_BODY]
#1462849
07/05/13 02:04 AM
07/05/13 02:04 AM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I enjoyed having a ladder bar car
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1462850
07/05/13 10:22 AM
07/05/13 10:22 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Going 8.50s to .90s won't be hard to do in a 2800 lb ladderbar car, but as Mike and others stated, they tend to be violent on the hit, and the car would need loooooong wheeliebars to run its' best. AMHIK. Even with 53 percent over the nose and a 106 WB, it is violent and would easily go on the bumper on any launch with some bite. That is with a Torqueflite, 33.6 tall tires, 4.56 gears. If you like the car , consider the possibility of going fourlink down the road if you are after the ultimate in adjustability. I live with mine because I like the violent launch. Its a blast!
[Re: bigtimeauto]
#1462852
07/05/13 01:01 PM
07/05/13 01:01 PM
MR_P_BODY
you guys need to buy some good shocks.
P body,is that pic in your sig a ladder bar?
No thats the 4-link.. that was for photos..it leaves like this normally
