Ministarter in a 440 #1462003
07/02/13 09:45 PM
07/02/13 09:45 PM
birdtracker Online boogie OP
birdtracker  Online Boogie OP
So in my 440 powered 86 W-150 I put headers. I tryed using a mini starter from a 95 Ram 1500 with a 5.9. I seemed to have picked up a noise. Seems in the bellhousing. Is there a fix? Or a different application starter? thanks. Birdtracker
Re: Ministarter in a 440 [Re: birdtracker] #1462004
07/03/13 12:03 AM
07/03/13 12:03 AM
N
NITROUSN Offline
NITROUSN  Offline
N
you most likely bent the metal seal/shield. Some mat require minor trimming if the starter nose and bolt holes dont line up.
