Wiper motor.....2 speed or 3 speed???? #146194
11/05/08 07:56 PM
11/05/08 07:56 PM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
Got a friend that's going to put a new Six Pak set up on his 1970 440 "Runner.
He has a 3 speed wiper motor.
Something tells me that (IIRC) that the air cleaner base will NOT work with a 3 speed wiper motor.
Anyone remember?
Re: Wiper motor.....2 speed or 3 speed???? [Re: superwrench] #146195
11/05/08 08:51 PM
11/05/08 08:51 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It won't work with a 2 speed motor.
The 3 speed was a manditory option on Hemi and Six Pack '66-'70 B bodies.
Re: Wiper motor.....2 speed or 3 speed???? [Re: B5 Bee] #146196
11/05/08 10:20 PM
11/05/08 10:20 PM
Exactly as I thought...thanks V Code.
As a matter of fact, I slipped up to my friend's place after work, and he does have the 2 speed motor....sticking right out where it's in the way!
My Challenger has the 2 speed motor, but there's at least an 1 1/2" more room at the rear of the engine at the firewall than the B Body has.
There-in lies the difference. My cleaner base has a good 3/4" of clearance.
SO...what's in the cards here? ....Get a 3 speed motor, linkage, switch and wiring and adapt?
Re: Wiper motor.....2 speed or 3 speed???? [Re: superwrench] #146197
11/06/08 12:10 AM
11/06/08 12:10 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
He'll need the motor,Switch and the crank that bolts to the motor then all should be well
NS1AAR
Re: Wiper motor.....2 speed or 3 speed???? [Re: ns1aar] #146198
11/06/08 01:36 AM
11/06/08 01:36 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
he's looking for motor #2983116 from a 70 B body. 68-70 will interchange, but you may want date coded.
Re: Wiper motor.....2 speed or 3 speed???? [Re: 1965_PLYMOUTH] #146199
12/30/08 01:41 AM
12/30/08 01:41 AM
If you are doing a conversion on a 1970-1971 E-Body or a 1971 B-Body from a 2-spd. to a 3 or variable spd. motor, you will have to replace the wiper motor crank with part #2822289, also the link from the motor to the drivers side pivot with part #2822293 (1970) or 3431102 (1971). Note the part #’s are stamped in these parts. The 1970 link will work on the 1971 and vice versa. These parts can be found on the cars listed above.
