Throttle cable length for a 1970 belvedere #1461852
07/02/13 02:26 PM
07/02/13 02:26 PM
Madill Oklahoma USA
K
kendalljones Offline OP
K
Madill Oklahoma USA
I have a 1970 Plymouth Belvedere 318 which I changed from a 2 barrel to a 4 barrel carb. I just rigged the original throttle cable to work but I would like to know if anyone knows the proper length. I think it may be 24" but not sure. I have a holley intake that has only a mild rise if any to it, I'm sure that the size of the intake may be an issue in finding out the correct size. Any help with this issue would be great or if there is such a thing as an adjustable cable that would be great as well. Thank you.
Re: Throttle cable length for a 1970 belvedere [Re: kendalljones] #1461853
07/02/13 03:29 PM
07/02/13 03:29 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Maybe I just got lucky, but I found that a 73-76 A body slant six cable is the same as a 70 B body V8!
Re: Throttle cable length for a 1970 belvedere [Re: Jjs72D] #1461854
07/03/13 03:30 PM
07/03/13 03:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
The six cylinder cable should be a lot longer than the V8 four barrel cables are OP, buy a four barrel replacement cable
