Sunroof lubrication #1461677
07/02/13 11:26 AM
07/02/13 11:26 AM
Lubbock, TX
E
Erics5th Offline OP
UsedtobeSatellite6
Erics5th  Offline OP
UsedtobeSatellite6
E
Lubbock, TX
The sunroof in my 5th Avenue "stutters" when I open and close it. Lubrication issue? If so, whats the best way to do it? My shop manual is no help, and I doubt its ever been lubed since it left ASC (company that did the conversion for Chrysler). Thanks.
Eric
Re: Sunroof lubrication [Re: Erics5th] #1461678
07/03/13 12:49 PM
07/03/13 12:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Try a little bit of white lithium grease on the moving parts . . . see how that goes . . .
Just my two cents . . .
PS - I have a 74 Duster360 with factory sunroof, and used that on the moving parts, seemed smoother to me. And this is a manual roof, not an electric powered one.
Cheers
Mark
Re: Sunroof lubrication [Re: Erics5th] #1461679
07/03/13 01:36 PM
07/03/13 01:36 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If it was me, I'd try one of the 'synthetics'...
A little goes a long way...
Doesn't react to temp...
Re: Sunroof lubrication [Re: RSNOMO] #1461680
07/03/13 03:17 PM
07/03/13 03:17 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Lube up any moving or rubbing parts.. I did this to my Merkur sunroof and was amazed at the difference
Re: Sunroof lubrication [Re: floridian] #1461681
07/04/13 11:14 AM
07/04/13 11:14 AM
Lubbock, TX
E
Erics5th Offline OP
UsedtobeSatellite6
Erics5th  Offline OP
UsedtobeSatellite6
E
Lubbock, TX
I'll tear into it today and see what I can do. I do have plenty of grease and synthetic spray around. Thanks.
Eric
Re: Sunroof lubrication [Re: Erics5th] #1461682
07/05/13 09:44 PM
07/05/13 09:44 PM
Lubbock, TX
E
Erics5th Offline OP
UsedtobeSatellite6
Erics5th  Offline OP
UsedtobeSatellite6
E
Lubbock, TX
Well, I removed the cable covers yesterday and found they where stretched, so I lifted them up and re-engaged them in the drive gear, lubed them up with white lithium grease and put them back into the cable guides. Works like its supposed to now! Thanks again for the help guys!
Eric
Re: Sunroof lubrication [Re: Erics5th] #1461683
07/05/13 11:03 PM
07/05/13 11:03 PM
a12rag Offline
a12rag  Offline
Great to hear . . . always the little things that make a BIG difference !!!
