cranking compression check #1460562
06/30/13 09:34 PM
06/30/13 09:34 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
408 roared back to life today after the cam swap. did a cranking comp. check with engine cold about 190avg. I think the old avg with the other grind was 175. so picked up atleast another 15psi. my question is when checking the cranking comp. is it recommended the engine be hot or does it not make any difference? ran out of time or I would have tried it hot. still need to check lash hot and retune carb mixture screws. I did notice the vacume reading was about 3" higher in gear.
Re: cranking compression check [Re: mopar dave] #1460563
06/30/13 09:40 PM
06/30/13 09:40 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Yes engine at operating temperature is what is recommended.
Re: cranking compression check [Re: mopar dave] #1460564
07/01/13 10:34 AM
07/01/13 10:34 AM
Az
Crizila Offline
Crizila  Offline
Az
Doesn't make any difference if you do it hot or cold as long as you do it the same way every time - same gauge, temp, # of pumps, battery fully charged ( I do one bank and then recharge the battery before I do the other bank ). You are really referencing between holes and the previous comp check. One check, by itself, only gives you limited info. A string of them, all done the same way, will be much more informative.
Fastest 300
Re: cranking compression check [Re: Crizila] #1460565
07/01/13 10:40 AM
07/01/13 10:40 AM
Mt Morris Michigan
Mt Morris Michigan
when I did it I had bat. charger on bat. and when it read 13.3v I would crank 6 times each cylinder. didn't sound like it cranks as fast as it used to. maybe bat. getting tired.
Re: cranking compression check [Re: Crizila] #1460566
07/01/13 11:07 AM
07/01/13 11:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... I do it cold just so I dont burn myself..its
just a reference to look back at
Re: cranking compression check [Re: mopar dave] #1460567
07/01/13 11:31 AM
07/01/13 11:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've done them cold and hot (well warm by the time you can work on it) not much difference often seems to be 2 to 5 lb lower warm heard that is as the oil film on the cylinders is thicker cold??
