Vac advance canister numbers #1460227
06/30/13 11:46 AM
06/30/13 11:46 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
the number stamped on the arm of advance units. is that number the advance degrees? the one I pulled apart has a 15 on it.
Re: Vac advance canister numbers [Re: chrisf] #1460228
06/30/13 12:54 PM
06/30/13 12:54 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
yes , that is the number of advance degrees , someone said it was 15 actual, but I can't see that ..
Re: Vac advance canister numbers [Re: chrisf] #1460229
06/30/13 01:10 PM
06/30/13 01:10 PM
It's the # of dist degrees & you double that # to get the # of crank degrees cuz the crank turns twice as fast as the cam/dist does & crank degrees is what you'll see with the timing light. Never seen one with that high of a # on it. could you post a pic?
