Re: which way does the center link go
[Re: hemi71x]
#1460173
06/30/13 01:12 PM
06/30/13 01:12 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It only can go on one way. The holes are tapered for the pitman arm, idler arm, tie rod ends. Line it up, and you will easily find out.
Actually, there are four potential ways a center link could go, but with the tapered holes it will only bolt in one of two possible ways.
If the center link is horizontally straight (as in a straight line between the holes) then it doesn't matter.
In this case there is a curve in the horizontal plane and the center link needs to be installed so that the curve is away from the oil pan.
As always, before you finish the job run the steering lock to lock to make sure you have clearance between the center link and anything else. This is especially critical if you are running after market parts like an oil pan, headers, lowered the car, offset bushings, etc.
[Re: Adam71Charger]
#1460174
06/30/13 01:31 PM
06/30/13 01:31 PM
Posts: 18,160 Mass
DAYCLONA
Mass
