fast idle when hot - 451ci #1460007
06/29/13 07:51 PM
06/29/13 07:51 PM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
ok guys, need a little help..
I have a 451 stroker (built by MM with plenty of power!), that i am having a little issue with when hot. I am trying to get everything dialed in for the Car Craft show in July..
My main issue, is that I have an issue when the car is hot, where it idles way up in park, and runs on if I turn it off with it in park (when the idle is up). I have a Quickfuel 830 on it, and everyone that has looked at the carb seem to think everything is setup properly with regards to idle and float positions. I had a bad vacuum leak in my power brake booster that has been resolved, an it doesnt appear to have any vacuum leak that I can see. I have read every post that i can find with these symptoms looking for a solution. I do have a new distributor(msd pro-billet RTR) that will arrive on Monday to replace the old chys electronic one i had, as well as replacing the old raggity spark plug cables to try to help rule anything from the ignition side.
I have read some people talk about a bad torque converter being a cause, and I might believe this for my car, as it currently likes to leak out the front of the transmission. It is a newer converter (5yrs) in a new trans (TCI SSFighter 727).
I also had some issues initially, as i didnt notice that the fuel pump that i was using, was a racing pump putting out 13psi. So it had initially run for the first couple hours of time on it, sending way too much PSI. I have put a regulator in it to take care of that, but wonder if it could have done something to the carb?
And lastly, timing could be an issue. My dad is set on the idea that it should be set at 8deg initial timing, as that is what the old 383 was supposed to be at. If i remember correctly it as at 12deg right now. What would you recommend to start at for initial timing for this combo?
Thx for your time!
Re: fast idle when hot - 451ci [Re: ebodykid] #1460008
06/29/13 08:02 PM
06/29/13 08:02 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
sounds like the throttle plates are open just a little too much.
Re: fast idle when hot - 451ci [Re: ebodykid] #1460009
06/29/13 08:09 PM
06/29/13 08:09 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If it's got any kind of cam in it, 16 initial minimum as long as it still starts OK when hot.
I set stock 318's at 12-14*...
Re: fast idle when hot - 451ci [Re: bonefish] #1460010
06/29/13 08:12 PM
06/29/13 08:12 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
Had same problem on my Demon,took me a while to find it and it was just the throttle cable being to tight after the engine was hot.
Re: fast idle when hot - 451ci [Re: coro500net] #1460011
06/29/13 08:24 PM
06/29/13 08:24 PM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
thanks for the responses so far.. I have the dizzy, and a new radiator (was up to 235deg last year at the show) set to arrive next week.. I will double-check the linkages, as I could see that maybe as an issue. We had to mess around with different springs to get it to feel right (has the taller edelbrock RPM intake) with the taller linkage bracket.
If anyone else has any ideas / input, please chime in as well.. the more help the better!
Getting the timing right, and figuring out this run-on issue will make me feel better.
I am hoping that a lightbulb will come on and I will see that obvious issue.
I will then just need to figure out my trans leak, and see if i can track down my little oil leak.. theres always something..
Re: fast idle when hot - 451ci [Re: ebodykid] #1460012
06/29/13 08:59 PM
06/29/13 08:59 PM
hooziewhatsit Offline
Add more timing, while limiting the total amount.
More initial will let you close the throttle blades a bit more.
Also, you may be on the edge of when mechanical advance kicks in. When it's warm, it idles faster naturally, which then provides more advance, so it idles faster still... Does the timing change between neutral and drive?
Re: fast idle when hot - 451ci [Re: hooziewhatsit] #1460013
06/29/13 09:14 PM
06/29/13 09:14 PM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
hmmm.. if i remember correctly, it did like to jump around when setting the timing on it, between n and d.. So you think upping the initial might help? The dizzy that had been in there had been recurved, but I have no idea what it was set to. I am going to start with the default curve on the new msd one that is coming to start.. I wish my parts were here so i could tinker with it.. with the weather and the new baby, i havent yet even fired my car up for the year
Re: fast idle when hot - 451ci [Re: ebodykid] #1460014
06/29/13 11:28 PM
06/29/13 11:28 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
its kinda hard to help without a pic of the car,everyone LIKES PICS!!!!
Re: fast idle when hot - 451ci [Re: ebodykid] #1460015
06/30/13 02:01 AM
06/30/13 02:01 AM
More initial may help. If not, you'll need to put a slightly stronger spring in the distributor (assuming your timing does change between drive and N).
Re: fast idle when hot - 451ci [Re: bonefish] #1460016
06/30/13 12:43 PM
06/30/13 12:43 PM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
ok.. heres some pics of the car in question!
i still wish i had my 70 challenger, but someone on moparts got a steal of the century back in the early 2000's.. i still wonder what that thing looks like today..
Re: fast idle when hot - 451ci [Re: hooziewhatsit] #1460017
06/30/13 02:54 PM
06/30/13 02:54 PM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
One thing that i have now just noticed (i had let my father do the distrubutor installation when it was first put in), is that the cap shows the rotation to be clockwise. This means that this was a smallblock Chy electronic distributor, correct? I havent yet found anything on the web to say what the curve is for this, but i'd imagine that the advance on this would be far different than what I'd want on a big block.. Would this make more sense to what you were saying about the spring weight?
I know that the only way to really find out is to play with it, so I am really anxious for my parts to arrive so i can put some of the suggestions to use..
Re: fast idle when hot - 451ci [Re: ebodykid] #1460018
06/30/13 03:52 PM
06/30/13 03:52 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The carb has an idle speed screw on the linkage side. You should be able to unscrew it and make the car stall....Can you?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: fast idle when hot - 451ci [Re: ebodykid] #1460019
06/30/13 05:48 PM
06/30/13 05:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if it were a smallblock distributor it would have no mechanical advance and a smallblock is CLOSE in size to a 440 distributor .
the cap markings do not matter because small and big block use the same cap , what side is the vac can on ?
Re: fast idle when hot - 451ci [Re: ebodykid] #1460020
06/30/13 08:21 PM
06/30/13 08:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
Two things come to mind,does that carb have a choke on it and if so is it electric and hooked up ? #2 I like to shorten the mechanical advance in the stock Mopar distributors by welding or adjusting (dependent on which version Mopar distributor )the travel in the mechanical advance slots so they have around 20 degrees total in the distributor so I can set the initial timing between 14 and 16 BTDC, which allows me to have between 34 and 36 degrees total timing revved up above 3000 RPM I do use the lightest advance springs I can get also, Mr Gasket Chevy springs work good in stock Mopar distributors On the choke, if it doesn't have one you may need to set the idle speed in gear around 800 to 900 when hot so it will idle when cold A properly tuned motor with the distributo set up properly will drop beween 100 and 150 RPM from nuetral to in gear, warm or cold. if it drops moe than that you may have to much mechanical advance in the distributor like the stock ones have, if it drops more RPM than that look at the timing changes between nuetral and in gear All things are possible when it comes to tuning and peforamance It's just a matter of figuring out what to modify to get the results you want
Re: fast idle when hot - 451ci [Re: coro500net] #1460021
07/01/13 05:26 AM
07/01/13 05:26 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
This ^ is usually the problem.
Just disconnect the throttle cable at the carb with the engine hot and idling high. If the rpm's drop the cable was just a little too tight. Give it some more slack.
Re: fast idle when hot - 451ci [Re: RobX4406] #1460022
07/01/13 09:46 AM
07/01/13 09:46 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
8 degrees is definitely not enough, and 12 most likely isn't either. 8 isn't even that good for the stock 383, which it isn't anymore.
Maybe you've got your curb idle set too high and its coming off the idle circuit to sustain a passable idle since the timing is low.
Re: fast idle when hot - 451ci [Re: GTX MATT] #1460023
07/05/13 05:20 PM
07/05/13 05:20 PM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
I didnt disappear
I have my new distributor and radiator installed in the car, and now i have a bad fuel pump... So I get to wait a little longer until Mancini's gets me my new pump before I can pull all the recommendations to use.. Like I said before, if its not one thing, its another.. At least with the pump replacement, every single thing in my engine compartment will be new.. Hopefully that means i get to run it for a few years problem free... I will check back in once it is running again to either let you all know if your suggestions fixed my issues, or if there is any new info...
thx guys!
Re: fast idle when hot - 451ci [Re: ebodykid] #1460024
07/05/13 05:42 PM
07/05/13 05:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
"if its not one thing, its another."
Get used to this concept. HotRod's test your patience, and the further from stock you get, the further your patience get tested. Not a good hobby for the guy that's "results oriented"; better for the "process oriented" type of fella.
Gorgeous car, BTW! Good luck finding the issue.
Re: fast idle when hot - 451ci [Re: StealthWedge67] #1460025
07/17/13 09:23 AM
07/17/13 09:23 AM
MN
E
ebodykid Offline OP
ebodykid  Offline OP
E
MN
Ok - Just an update
With the new radiator, even with the hot days (90+) the cars hasnt had its temp climb above 190. It also hasnt yet idled up on me, nor run on. I have the timing set at 16 initial as suggested, with the stock 21 of advance in the the msd distr. Car Craft is this weekend, so sitting and idling while trying to get into the show will be the real test, but it seems that with just the timing recommendation, new distr and plug wires, and the fact that it doesnt get so damn hot with the new radiator, this might be all resolved. I also got my bad vibration at 60+ mph all figured out, (missing c-clips on back u-joint allowed it to shift in the cradle), and the trans seems to be happy and fluid level back to where it should be (air bubble caused me issues?), so i am feeling pretty good about things right now..
If you are at the car craft show stop and say hi! I will be near the Mr Norms 440 dart, and a bright red NSX.
