70 Cuda Heater Control Cables? Non A/C #1459931
06/29/13 03:00 PM
06/29/13 03:00 PM
Council Bluffs Iowa
belv383 Offline OP
belv383  Offline OP
Council Bluffs Iowa
Getting Ready To Put My Dash Assembly In My 70 Cuda, Could Use Some Info On How To Route Heater Control Cables Around Clutch Pedal And Defroster Vent, Heater Box Is In Car Just Want To Get Cables Routed Right The First Time. Anyone Have Pictures Of Underdash?
Re: 70 Cuda Heater Control Cables? Non A/C [Re: belv383] #1459932
07/01/13 09:12 PM
07/01/13 09:12 PM
CT
1932chrysler Offline
CT
here is the routing on a challenger
this photo was taken right after dash assembly was removed
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: 70 Cuda Heater Control Cables? Non A/C [Re: 1932chrysler] #1459933
07/02/13 07:49 PM
07/02/13 07:49 PM
Council Bluffs Iowa
belv383 Offline OP
belv383  Offline OP
Council Bluffs Iowa
Thank You For The Picture! Does 1 Cable Run Behind Defr Vent And Other In Front? Both Appear To Run Through Steering Column Support To The Control Panel.
Re: 70 Cuda Heater Control Cables? Non A/C [Re: 1932chrysler] #1459934
07/14/13 06:35 PM
07/14/13 06:35 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Here'd the layout.
Re: 70 Cuda Heater Control Cables? Non A/C [Re: Topcat] #1459935
07/14/13 06:35 PM
07/14/13 06:35 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
One more...
