413 car block/dipstick with truck oil pan issue #1459805
06/29/13 12:28 AM
06/29/13 12:28 AM
Terre Haute, Indiana
bgilbert Offline OP
bgilbert  Offline OP
Guys I'm putting a 1965 413 into a 74 W300 pickup. This block has the hole in the block for the dipstick, not the pan like the trucks. I've installed a truck oil pan and would've used the 'car' dipstick, but it won't fit with the rear sump truck pan. I've got a truck dipstick, no problem, but my question is what to do with the hole in the block? I imagine with crank pressure a plug could blow out under high rpm? The opening in the block is relatively close to 1/8"NPT size. Would it be sacrilegious to drill and tap the hole or could it weaken the block? Suggestions?
85 D350 crew with 90 Cummins 6BT Getrag 3.07 93 D350 single cab Getrag 3.54 74 W300 360 4 speed 4.88 70 front/rear
Re: 413 car block/dipstick with truck oil pan issue [Re: bgilbert] #1459806
06/29/13 12:45 AM
06/29/13 12:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Trucks have the same hole its just plugged. You can use silicone, a small frost plug or hunk of brass, jb weld etc etc. Truck pan has the dipstick in the side of the pan
Re: 413 car block/dipstick with truck oil pan issue [Re: 76dodgeboy] #1459807
06/29/13 01:13 AM
06/29/13 01:13 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: 413 car block/dipstick with truck oil pan issue [Re: 76dodgeboy] #1459808
06/29/13 01:43 AM
06/29/13 01:43 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I tapped my block and put in an allen head pipe plug, no problem. Used the Milodon deep pan and their flexible dipstick.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 413 car block/dipstick with truck oil pan issue [Re: Polarapete] #1459809
06/29/13 11:58 PM
06/29/13 11:58 PM
bgilbert Offline OP
bgilbert  Offline OP
Thanks I did the same. The hole in the block is already 'drilled' out to 1/8"npt tap size, I didn't have to drill it, just run the tap in. Pretty easy.
Re: 413 car block/dipstick with truck oil pan issue [Re: bgilbert] #1459810
07/02/13 12:55 AM
07/02/13 12:55 AM
South Coast of Oregon
dweller Offline
dweller  Offline
Factory truck and marine engines just had an aluminum plug driven into the hole with some sealant...
Re: 413 car block/dipstick with truck oil pan issue [Re: dweller] #1459811
07/08/13 11:29 PM
07/08/13 11:29 PM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
How did you get the motor mount brackets bolted to the block?
Re: 413 car block/dipstick with truck oil pan issue [Re: Carsavior] #1459812
07/08/13 11:47 PM
07/08/13 11:47 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
With bolts
I am truckless..
Re: 413 car block/dipstick with truck oil pan issue [Re: 340SHORTY] #1459813
07/09/13 12:19 AM
07/09/13 12:19 AM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
The 413 in my New Yorker had no "ears" on one side of the block (drivers I think) to mount a conventional bracket to. Used a different style of bracket.
Re: 413 car block/dipstick with truck oil pan issue [Re: Carsavior] #1459814
07/09/13 12:50 AM
07/09/13 12:50 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
That would nessatate a front motor plate IMO..
Re: 413 car block/dipstick with truck oil pan issue [Re: Carsavior] #1459815
07/09/13 01:16 PM
07/09/13 01:16 PM
bgilbert Offline OP
bgilbert  Offline OP
This block had them.
