Torque Converter 360 #1459658
06/28/13 06:43 PM
06/28/13 06:43 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
My question is pertaining to the torque converter on my dad's 85' Dodge 360.
He has recently rebuilt the engine and has converted it from an external balance to an internal balance crankshaft. Can he simply knock the counterweight off his external balance torque converter or does he need to replace the torque converter for an internal balance one?
He knocked the counterweight off and has been driving it on and off. Once in a while the truck starts to feel like its bouncing around as if it has a flat tire. Any ideas if the converter is the root of the problem?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Torque Converter 360 [Re: CurYellowBird] #1459659
06/28/13 06:48 PM
06/28/13 06:48 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
What about the damper in the front? Doesnt that have a groove cut out for balance in the front?
Re: Torque Converter 360 [Re: CurYellowBird] #1459660
06/28/13 06:51 PM
06/28/13 06:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have just taken the weight of a number of them with no problems. That is all that neutrally balanced converter is. Did he change the vibration damper at the front?
Re: Torque Converter 360 [Re: CurYellowBird] #1459661
06/28/13 10:34 PM
06/28/13 10:34 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
It should be fine to just take the weight off the converter.
It's Swifty! Swifty, you toad sucker!
Re: Torque Converter 360 [Re: zrxkawboy] #1459662
06/28/13 11:30 PM
06/28/13 11:30 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
If you converted the 360 to internal balancing then the balancer also will have to be changed. It is part of the external balancing as well as the torque converter weight unless the engine was balanced with the original balancer.
Re: Torque Converter 360 [Re: 82ramIndy493] #1459663
06/30/13 05:58 AM
06/30/13 05:58 AM
Upper Midwest
Upper Midwest
Then it would still be externally balanced
