Re: Cleaning wideband o2 sensor?
[Re: Cab_Burge]
#1459021
06/27/13 06:21 PM
06/27/13 06:21 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Are you using race gas with lead or non leaded pump gas? If race gas it may be that, lead, is what is causing the problems How close to the exhuast valves is the sensor? closer is better, more heat
water/meth inject will keep it clean...
[Re: Duner]
#1459023
06/27/13 06:32 PM
06/27/13 06:32 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure on some of these other systems but once in awhile you have to do a "clean air" reboot I guess you would call it. Remove it and turn the system on while its hooked up and out. Mine is reading wrong right now so I will be trying it for this weekend.
[Re: radar]
#1459025
06/28/13 02:27 PM
06/28/13 02:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Brakeleen works but get it dry before you use it. Sometimes getting the tune right will clean em up too
I've used brakeclean in the past.. sometimes it works but its worth a try.. if its that bad now its scrap, so give it a try
[Re: FastmOp]
#1459027
06/28/13 03:46 PM
06/28/13 03:46 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I googled it just for the heck of it and it looks like several recommend soaking it in gas over night and blowing it out with air.
