Rod to block clearence #1457303
06/23/13 10:47 PM
06/23/13 10:47 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
On a 360 stroked to a 410, what should
the clearence be between the rod bolt and the block?
Re: Rod to block clearence [Re: moparmikethree] #1457304
06/23/13 10:55 PM
06/23/13 10:55 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Steel rods ?
Re: Rod to block clearence [Re: dOc !] #1457305
06/23/13 10:56 PM
06/23/13 10:56 PM
yes steel rods
Re: Rod to block clearence [Re: moparmikethree] #1457306
06/23/13 11:21 PM
06/23/13 11:21 PM
I think .050" would be more than enough. Individuals have gone with as tight as .030 quench on the other end with all the rod stretch to be accounted for tho some of that is for piston rock & you wouldn't have any stretch really on the big end. It'd be easy to notch the cyls for that amt of clearance.
Re: Rod to block clearence [Re: RapidRobert] #1457307
06/23/13 11:36 PM
06/23/13 11:36 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Always used a paper clip as a gauge, or about .060.
Re: Rod to block clearence [Re: 4406bbl] #1457308
06/24/13 10:43 AM
06/24/13 10:43 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
It's not rocket science. I just eyeballed mine and have no problems. If you use H beam rods no grinding necessary.
Re: Rod to block clearence [Re: babarracuda] #1457309
06/24/13 11:34 AM
06/24/13 11:34 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I used a zip tie - that measured out at .060 and it worked great - you can hold it loose and stab it in there or wrap the rod in it and spin it to see if it clears.
Re: Rod to block clearence [Re: DJVCuda] #1457310
06/24/13 12:41 PM
06/24/13 12:41 PM
dogdays Offline
dogdays  Offline
60 should be more than enough. If your crankshaft is deflecting that much you've got real problems. Shoot, how tight do people make crank scrapers?
R.
Re: Rod to block clearence [Re: 4406bbl] #1457311
06/24/13 02:53 PM
06/24/13 02:53 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Rod to block clearence [Re: dogdays] #1457312
06/24/13 09:20 PM
06/24/13 09:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
R.
0.030"
