Set ride heights and set up four link today
#1457250
06/23/13 07:49 PM
06/23/13 07:49 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Set up ride heights at 3 3/4 front and 4 inch rear four link 45 inch out and 6 1/2 up. Finished plumbing vacuum pump and installed delay box and starting line enhancer and put on headers. Not sure I will finish this summer but chipping away at it. Can some one recommend a reasonably economical flare tool for AN brake lines 17 degrees.
76 Duster
work in progress
Re: Set ride heights and set up four link today
[Re: Edge]
#1457251
06/23/13 08:03 PM
06/23/13 08:03 PM
Edge
Alberta Canada
With front clip on, wheel base is stretched to 110. Regret not making the the front spoiler another 1 inch lower.
76 Duster
work in progress
[Re: CHAPPER]
#1457253
06/23/13 11:55 PM
06/23/13 11:55 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1457254
06/24/13 12:07 AM
06/24/13 12:07 AM
Edge
Alberta Canada
thanks, right 37 degree is what I was looking for, have you tried flaring stainless with the flaring tool, thanks for the lead, price is really good
76 Duster
work in progress
[Re: Edge]
#1457257
06/24/13 02:31 PM
06/24/13 02:31 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
this is a very good flaring tool. I have it and it works awesome. it is not recommended for stainless. I use aluminum line for everything.
http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=212FB
for stainless, u should use the imperial 400-F, which is about $350.
you may be able to use the rigid 377, ($125) for stainless, but isnt designed for it.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: Edge]
#1457259
06/24/13 04:42 PM
06/24/13 04:42 PM
Posts: 43,364 Bend,OR USA
Cab_Burge
I bought one from Parker Hanakin years ago for using on my airplane, I have never treid it on Stainless lines though I does a great job on both hard and regular alumimin lines 1/8 (#2) inch to 5/8(#10)
[Re: Joes66dart]
#1457262
06/24/13 10:40 PM
06/24/13 10:40 PM
Edge
Alberta Canada
thanks, I will pick up the Rigid flaring tool for making up the lines.
I will try to get some pictures of the set back and mounting of the motor but it is really typical for any chassis car
76 Duster
work in progress
