Re: push button tranny cable
[Re: plymouth62]
#1457207
06/23/13 05:16 PM
06/23/13 05:16 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The cable housing is full of fluid up to the fluid level in the trans; there is a rubber sheath around the lower part of the cable housing to prevent fluid leaks, if that sheath is damaged it will leak fluid.
Heat shrink tubing can be used to repair a damaged sheath; some heat shrink contains a glue, it works best. Be sure the heat shrink extends up onto the metal end of the cable housing.
Also, be sure the leak isn't coming from above the cable at the TP lever shaft.
[Re: plymouth62]
#1457209
06/23/13 07:58 PM
06/23/13 07:58 PM
John_Kunkel
Rio Linda, CA
If it was the Sacramento Del Monte it could have been the jerk with a different middle initial that kept fouling up my credit...no relation.
[Re: Cab_Burge]
#1457212
06/24/13 05:29 PM
06/24/13 05:29 PM
John_Kunkel
Rio Linda, CA
Which one of you two flew Piper airplanes or did you?
Musta been me, had an Arrow and a Cherokee 140.
