http://www.heat-treat-doctor.com/documents/CastIrons.pdfThis has a nice phase diagram of iron-carbon-silicon (grey cast iron). It shows a melting point near 2100 F. Here are some brief highlights from the text:
"Stress
relief is done at temperatures between 1020
and 1200°F (550 and 650°C) without significantly
lowering strength and hardness.
Heating at temperatures between 1290 and
1400°F (700 and 760°C) lowers the hardness
for improved machinability. Ferritizing (for the most ductile
microstructure) is done by austenitizing at
1650°F (900°C), followed by holding at
1290°F (700°C) to completely transform austenite to ferrite and graphite."
So, if the temps were low (not likely as the aluminum completely melted) then they would be merely stress relieved. More than likely the hardness has changed. I would expect them to be scrap unless they are rare and expensive blocks. You might be able to heat treat them back to a useable form if they are rare. Most likely would have to machine every critical surface.
