Re: 400 deck clearance?
[Re: WO23Coronet]
#1456979
06/23/13 09:15 AM
06/23/13 09:15 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't see any reason why the 400s would be any different than the 383s and 440s, but I've never measured a 400 block.
I can say that I built a 383, they cut the decks .015 to square them up. AFTER the cut, they were AT blueprint spec. (what was that spec again? 9.980"?
**Photobucket sucks**
[Re: WO23Coronet]
#1456982
06/23/13 08:31 PM
06/23/13 08:31 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Did the 72-78 400's use the same pistons?
probably something very close, a SMOGGER 440 would have a piston roughly .180 down.
I JUST RAN SOME NUMBERS AND A 400 WITH A PISTON IN THE HOLE .180 AND A 90CC HEAD WOULD HAVE A 6.85 COMPRESSION RATIO , I DOUBT IT'S THAT LOW.
Sorry for the caps lock , i'm not retyping that ...
[Re: JohnRR]
#1456983
06/24/13 12:58 PM
06/24/13 12:58 PM
dogdays
And folks wonder why the 400 had a reputation as a dog....... So I went to Silvolite website and found 400 pistons stock replacement, 1.812" comp height, which puts the top of piston about 0.120 down. So maybe all 400s were the same.
R.
[Re: dogdays]
#1456984
06/24/13 02:39 PM
06/24/13 02:39 PM
JohnRR
R.
They are very close to that, .100 comes to mind.
I looked at a rebuilt 400 a number of years back that was zero deck and I remember seeing that the intake had been cut .120 ...
