How do you get the trans radiator line off a Cherokee #145676
11/04/08 07:30 PM
11/04/08 07:30 PM
Indianapolis
Waveraider Offline OP
Indianapolis
I"m replacing the radiator on my '98 Jeep Cherokee and can't get the lower trans line that hooks up to the radiator off. Is there a special tool or what do you do to get that thing off? Thanks.
Re: How do you get the trans radiator line off a Cherok [Re: Waveraider] #145677
11/04/08 07:51 PM
11/04/08 07:51 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Mine blew off one time. I think it's a push in and lock type. You may have to compress or squeeze tabs to unlock it. It was several years ago when it blew off.
Re: How do you get the trans radiator line off a Cherokee [Re: Waveraider] #145678
11/04/08 08:13 PM
11/04/08 08:13 PM
PA
70Duster Offline
70Duster  Offline
PA
There are plastic tabs on opposing sides of the fitting that have to be pressed simultaneously in order to pull it off. Often times, it helps to push in while you are depressing the tabs and then pull the line off.
Re: How do you get the trans radiator line off a Cherokee [Re: 70Duster] #145679
11/04/08 08:35 PM
11/04/08 08:35 PM
Indianapolis
Indianapolis
Hmmm. I noticed those plastic tabs on the other line, but there isn't any on this one. I wonder if they broke off.
Re: How do you get the trans radiator line off a Cherokee [Re: Waveraider] #145680
11/05/08 08:08 AM
11/05/08 08:08 AM
Indianapolis
Indianapolis
Bump for the morning crowd.
