1971 Challenger Ground Strap #1456394
06/21/13 11:46 PM
06/21/13 11:46 PM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
Does anyone have a pictures of where the under hood ground straps goes on a 71 Challenger with A/C.
Frame to firewall?
68 Coronet R/T Hemi
70 Challenger 440-6
70 Challenger R/T S/E 440-6
71 Challenger Convert.
70 Superbird 440-6
Re: 1971 Challenger Ground Strap [Re: Knappy] #1456395
06/21/13 11:54 PM
06/21/13 11:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The negative battery cable has two leads, the small one goes to the radiator support for the body ground.
Re: 1971 Challenger Ground Strap [Re: Alaskan_TA] #1456396
06/22/13 09:49 AM
06/22/13 09:49 AM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
Is that the only ground? I bought a ground cable from Year One that says it connects to the right side cylinder head to firewall. It may be for a B-body.
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
Re: 1971 Challenger Ground Strap [Re: Knappy] #1456397
06/24/13 03:31 PM
06/24/13 03:31 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
and,at least on my -70 theres a thin cable for the ac that grounds on the lower wipermotor stud. the year one stuff sounds strange
Re: 1971 Challenger Ground Strap [Re: cuda-sweden] #1456398
06/24/13 04:40 PM
06/24/13 04:40 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Later on in 73, they added a rear ground strap on the E-bodies. My Oct built car doesn't have one. I assumed the earlier years just used the negative cable.
Re: 1971 Challenger Ground Strap [Re: burdar] #1456399
06/25/13 11:48 AM
06/25/13 11:48 AM
WNY
slimert Offline
slimert  Offline
WNY
Have a ground that is on the firewall. It looks like it comes from the fan motor wiring harness. Not sure what's correct as this was all missing from the car when I purchased it.
Re: 1971 Challenger Ground Strap [Re: slimert] #1456400
06/28/13 01:54 PM
06/28/13 01:54 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
aha,i see ac.so that could be the cable that should be on the wipermotor stud.
