Page 2 of 3 1 2 3
Re: What does 75cc E-Street chamber look like? [Re: RAMM] #1455687
06/27/13 05:29 PM
06/27/13 05:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Anyone else see some "interesting" things w/ this 2013 Edelbrock BB Chrysler cylinder head listing?
Re: What does 75cc E-Street chamber look like? [Re: BradH] #1455688
06/27/13 05:33 PM
06/27/13 05:33 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
They list a 75cc Performer RPM head.
Re: What does 75cc E-Street chamber look like? [Re: gpuller] #1455689
06/27/13 07:54 PM
06/27/13 07:54 PM
New Lenox il.
CARMAN Offline
CARMAN  Offline
New Lenox il.
Here is a pic of the 75 cc chamber e heads that I just purchased.
Re: What does 75cc E-Street chamber look like? [Re: CARMAN] #1455690
06/27/13 08:09 PM
06/27/13 08:09 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Yes! We have a picture! Thanks for posting! Anyone have any flow numbers to compare to the RPM?
Re: What does 75cc E-Street chamber look like? [Re: 67Satty] #1455691
06/27/13 09:43 PM
06/27/13 09:43 PM
Out of the State of Confusion
blue_stocker Offline
Interestingly, I called Edelbrock today, talked to Ron but there was no 'engineer' about who could answer my questions about the 'modern chamber design' and I guess their own tech guys aren't aware of their own products, so I reckon I'll be on the phone in the morning.
Re: What does 75cc E-Street chamber look like? [Re: CARMAN] #1455692
06/27/13 11:10 PM
06/27/13 11:10 PM
BradH Offline
BradH  Offline
What model of head is that (E-Street or Performer RPM) and is that CNC chamber work the way it comes OOB from Edelbrock?
Re: What does 75cc E-Street chamber look like? [Re: CARMAN] #1455693
06/28/13 08:07 AM
06/28/13 08:07 AM
The Great White North
RAMM Offline
RAMM  Offline
Wow it looks like a decent turbo chamber but still looks sorely lacking for an NA engine-in the pressure recovery department. I could be wrong though as I am judging from a picture. I hope mine are more promising when I get them. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: What does 75cc E-Street chamber look like? [Re: RAMM] #1455694
06/28/13 11:12 AM
06/28/13 11:12 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What's pressure recovery, and what does the chamber have to do with it? And btw it looks like the RPM's are NHRA legal for stock/super stock (I think that's what BradH was referring to)
Re: What does 75cc E-Street chamber look like? [Re: WO23Coronet] #1455695
06/28/13 12:24 PM
06/28/13 12:24 PM
BradH Offline
BradH  Offline
I'm interested in this, too. I know what pressure recovery is, but am not clear on how the chamber design impacts this.
Actually, no. I think the NHRA-legal castings have been out for a while now, but since I don't follow the Stock / Super Stock stuff very closely, don't know anything about them.
I was referring to other things, such as the new 75 cc Performer RPM option and the spec on the revised Victor chamber being 72 cc, instead of the original 75 cc.
Re: What does 75cc E-Street chamber look like? [Re: WO23Coronet] #1455696
06/28/13 01:25 PM
06/28/13 01:25 PM
RAMM Offline
RAMM  Offline
Take a good look at the Kaase P-51 chamber. Here you will see an effort soley focused on maximum pressure recovery. Valve shrouding via the chamber wall can be good.I have made mistakes in the past by deshrouding. The valve position relative to bore centerline on a Big Mopar Wedge is terrible so it is very hard to design a nice chamber; however it should be better than some of the current offerings. J.Rob
Re: What does 75cc E-Street chamber look like? [Re: RAMM] #1455697
06/28/13 03:28 PM
06/28/13 03:28 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I like the 75 number but ....only to 5500 rpms .....
You are buying a brand new Edelbrock # 5090 E-Street Performance Aluminum Cylinder Heads for Big Block Mopar V8 Engines.These Cylinder Heads are made for 1961-1979 Big Block Mopar 361-440 V8 Engines. Edelbrock's all new line of Cylinder Heads are designed for entry-level street performance engines and ideal for operating in the idle to 5500 RPM range. Manufactured in the USA, by Edelbrock, these Cylinder Heads Feature:
Re: What does 75cc E-Street chamber look like? [Re: dOc !] #1455698
06/28/13 04:00 PM
06/28/13 04:00 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Well, with stock port volume, 5500 is quite realistic. You want to start winding it out, get some porting or go to Victors, Indy or B-1s S/F.....Ken M
Re: What does 75cc E-Street chamber look like? [Re: EchoSixMike] #1455699
06/28/13 04:29 PM
06/28/13 04:29 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I have never actually run a set of Eddy heads ...or even 440S pieces ... so OOTB they all have a TOP flow rate of 5500 rpm?
Re: What does 75cc E-Street chamber look like? [Re: dOc !] #1455700
06/28/13 04:52 PM
06/28/13 04:52 PM
BradH Offline
BradH  Offline
... OOTB they all have a TOP flow rate of 5500 rpm?
Limited by valve train components (i.e., soft springs for mild hydraulic cams), not by port volume or flow.
Re: What does 75cc E-Street chamber look like? [Re: BradH] #1455701
06/28/13 04:58 PM
06/28/13 04:58 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
So BH ..... so a box-stock set of 75cc heads ... with a good set of springs using a 557 or 590 solid-lifter cam....with a 480 inch moder ... 6200 hUn ?
Re: What does 75cc E-Street chamber look like? [Re: CARMAN] #1455702
07/02/13 08:17 PM
07/02/13 08:17 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Did Edelbrock change the casting? In some other older posts people said that the chamber was identical to the RPM. Well, the whole head was said to be identical except the chamber size of 75cc.
Re: What does 75cc E-Street chamber look like? [Re: DGS] #1455703
07/02/13 10:20 PM
07/02/13 10:20 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
For reference, here's a set of (early)Victors. S/F.....Ken M
Re: What does 75cc E-Street chamber look like? [Re: EchoSixMike] #1455704
07/08/13 10:55 PM
07/08/13 10:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
looks like some pics have already made their way onto the thread.
here's a couple more:
chamber, no valves.
in these pics i have already re-cut the valve seats, so you are not looking at the as-supplied Edelbrock valve job.
Re: What does 75cc E-Street chamber look like? [Re: fast68plymouth] #1455705
07/08/13 11:05 PM
07/08/13 11:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
you can see by this pic the valve seats are noticably recessed into the chamber roof.
you can also see they have lowered the roof some between the valves. this is evident because they needed to put a little trough coming off the spark plug hole.
on the 84cc head, the plug hole is clear of the roof.
also, as for these heads being "milled" to get the 75cc's.....while they didnt just mill an 84cc head down to remove 9cc's, they have done some machining of the casting in a way to help make the chambers smaller.
there is a "D" shaped pad on the deck of an 84cc head, along the intake side of the head, mid-way from front to back.
this pad is about .030 deep on the 84cc head.
on the 75cc E street head, its basically gone.
however....the head bolt boss thickness is the same as an 84cc head.....not .030 thinner.
also, you dont lose .030 of valve drop....its more like .015.
Re: What does 75cc E-Street chamber look like? [Re: fast68plymouth] #1455706
07/08/13 11:08 PM
07/08/13 11:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
84cc RPM head with a Fel-Pro 1009 gasket.
notice how the chamber really follows the contours of the gasket adjacent to the intake valve.
Page 2 of 3 1 2 3
