Page 1 of 3 1 2 3
What does 75cc E-Street chamber look like? #1455667
06/20/13 02:35 PM
06/20/13 02:35 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I see a bunch of posts on Edelbrock and Stealth heads and have a related question about what the 75cc Edelbrock E-Street chamber look like. I can't find any pictures of one.
Also, I just stumbled across Hughes web site and they list a CNC-ported version of that 75cc E-Street head now.
Re: What does 75cc E-Street chamber look like? [Re: PorkyPig] #1455668
06/20/13 04:04 PM
06/20/13 04:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
All the pics I see have E-street stamped on them but the camber looks like the 84cc to me.
Mopar to the bone!!!
Re: What does 75cc E-Street chamber look like? [Re: 72Swinger] #1455669
06/20/13 04:10 PM
06/20/13 04:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Uhhhh... like an 84 cc chamber milled to reduce it by 9 cc?
Re: What does 75cc E-Street chamber look like? [Re: PorkyPig] #1455670
06/20/13 04:25 PM
06/20/13 04:25 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I think he means combustion chamber design -
open chamber, closed chamber, heart-shaped, modern, old design etc etc
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: What does 75cc E-Street chamber look like? [Re: VincentVega] #1455671
06/20/13 05:40 PM
06/20/13 05:40 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
It would be nice if you could get them bare.
Re: What does 75cc E-Street chamber look like? [Re: 72Swinger] #1455672
06/20/13 05:55 PM
06/20/13 05:55 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
I've only seen them in 84cc chambers. Are the 75's out yet?
Re: What does 75cc E-Street chamber look like? [Re: gpuller] #1455673
06/20/13 06:08 PM
06/20/13 06:08 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Re: What does 75cc E-Street chamber look like? [Re: 72Swinger] #1455674
06/20/13 06:33 PM
06/20/13 06:33 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
that works. looks like the standard old school 915 chamber, although it does say
" Modern Combustion Chamber designs improve the combustion process "
grain/salt
Re: What does 75cc E-Street chamber look like? [Re: VincentVega] #1455675
06/20/13 08:27 PM
06/20/13 08:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This is why I dont think the pic is actually of a 75cc chamber. http://www.ebay.com/itm/Edelbrock-383-44...54f&vxp=mtr
Re: What does 75cc E-Street chamber look like? [Re: 72Swinger] #1455676
06/21/13 10:05 PM
06/21/13 10:05 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Its the same head as the 88/84 Just Cut to 75
Still has small standard mopar runner volumes
Re: What does 75cc E-Street chamber look like? [Re: joshking440] #1455677
06/23/13 10:25 PM
06/23/13 10:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
i have a set in the shop......i'll get a few pics posted.
it is NOT an 84cc chamber milled to 75cc.
it is basically a heart shaped design, and is pulled in adjacent to the valves, which does put a little hurtin on the mid-lift flow numbers.
the OOTB flow in the mid-lifts isnt too good, but they do respond well to some tweeking.
oh, and the one chamber i checked the volume on was 74.4cc, AFTER i re-cut the seat and cleaned up the chamber.
so that particular chamber was probably around 73.5cc OOTB.
Re: What does 75cc E-Street chamber look like? [Re: fast68plymouth] #1455678
06/23/13 10:38 PM
06/23/13 10:38 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Thanks, I was hoping they were basically a Victor chamber.
Re: What does 75cc E-Street chamber look like? [Re: fast68plymouth] #1455679
06/23/13 11:11 PM
06/23/13 11:11 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Thanks for stepping in with some data Dwayne How do they compare to the RPM heads overall?
Re: What does 75cc E-Street chamber look like? [Re: fast68plymouth] #1455680
06/24/13 02:43 PM
06/24/13 02:43 PM
BradH Offline
BradH  Offline
Those comments sound like what Brian H. (ou812) said about testing the latest BB Victors that have a smaller (more Indy-like, IMO) chamber.
Just out of curiosity, does the difference in valve seat material between the original Performer RPM and later E-Street heads mean that you'd expect the E-street valve job to get pounded out faster w/ the same spring loads, etc.? Or would they be more prone to being damaged from running high(er) spring pressure?
Also, do they come w/ the same valves, or are the E-Street parts more budget-oriented and come w/ cheaper and/or heavier pieces?
Re: What does 75cc E-Street chamber look like? [Re: BradH] #1455681
06/24/13 04:09 PM
06/24/13 04:09 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Thats odd Dwayne.
When I called my Edelbrock Sales guy about this for a customer he was very frank about it. Sounds like he wasnt as sure as he sounded
Re: What does 75cc E-Street chamber look like? [Re: fast68plymouth] #1455682
06/24/13 06:02 PM
06/24/13 06:02 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Do you have any flow numbers to compare to the RPMs and the Stealths?
Re: What does 75cc E-Street chamber look like? [Re: 67Satty] #1455683
06/25/13 12:17 AM
06/25/13 12:17 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Damn.....I was hoping I would see some pics tonight, I know Dwayne is probably pretty busy though.
Re: What does 75cc E-Street chamber look like? [Re: BradH] #1455684
06/25/13 01:01 PM
06/25/13 01:01 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
What difference is there in the valve seats?
Re: What does 75cc E-Street chamber look like? [Re: PorkyPig] #1455685
06/25/13 02:09 PM
06/25/13 02:09 PM
If your running a stainless valve or a Titainimum valve you need the correct seats in the heads to match the valves used
Re: What does 75cc E-Street chamber look like? [Re: Cab_Burge] #1455686
06/27/13 08:06 AM
06/27/13 08:06 AM
The Great White North
RAMM Offline
RAMM  Offline
I was really hoping somebody could post up a few pics of the new chambers. I have scoured the 'net and all I kind find is the old ugly chamber. I even called Edelbrock and they don't have any kind of pictures/data/CAD or measurements? Guess they fly by the seat of their pants and eyeball everything. Jeez. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Page 1 of 3 1 2 3
