Re: Just finished installing carbon fibre spoiler on Duster
[Re: Clanton]
#1455126
06/19/13 01:20 AM
06/19/13 01:20 AM
Posts: 698 Alberta Canada
Edge
Alberta Canada
I would assume a fair bit of down force but who knows maybe it is just for show. Dimensionally it is pretty similar to the spoiler on a friends top sportsman car (6.90 car) and the amount of down force on his chassis is really significant on the top end based on the reading from his shock travel sensors. If necessary I can mess with the angle of the spoiler at some point as the support struts are adjustable. I am just pleased that it turned out ok.
76 Duster
work in progress
[Re: Edge]
#1455128
06/19/13 11:30 AM
06/19/13 11:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm sure you wont have to change any angles... the air is falling off the roof line and its that wing pretty hard... depending on speed you should see a few hundred pounds of force
[Re: MR_P_BODY]
#1455129
06/19/13 01:11 PM
06/19/13 01:11 PM
Posts: 22,798 Bitopia
jcc
Bitopia
I would have a hard time calling the Op's addition a wing, mainly because air only acts on one side of it. Regardless, by adding/reducing the "gurney flap", it can be significantly tuned, even though it really is more of a spoiler in this case. http://en.wikipedia.org/wiki/Gurney_flap
[Re: jcc]
#1455130
06/19/13 02:24 PM
06/19/13 02:24 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
OHHHHHHHH.......you meant a wickerbill. O.K. , point taken. But it looks great and should add stability as well as down force. I like it.
[Re: Edge]
#1455133
06/19/13 04:01 PM
06/19/13 04:01 PM
Edge
Alberta Canada
And the flywheel 168 tooth had to be replaced also due to the SFI 6.3 spec.
76 Duster
work in progress
[Re: mopartony]
#1455135
06/19/13 09:38 PM
06/19/13 09:38 PM
Edge
Alberta Canada
Its a universal wing from Bickel took some trimming but no big deal
76 Duster
work in progress
