Re: Eldebrock RPM's vs. 440 Source Stealth heads
[Re: '72CudaRacer]
#1455068
06/19/13 01:58 PM
06/19/13 01:58 PM
BradH
Where did the Stealth head crack and is it not repairable? I don't bother following the Stealth-related posts often; is this a common problem with them? I don't recall the Edelbrocks having cracking issues, etc., although I've seen first-hand how IMO they still need to have the guide clearances & valve jobs checked & corrected OOB. Performance-wise there shouldn't be any significant difference with the same level of prep work, considering Brandon's R&D for port & chamber design was simply sending an Edelbrock Performer RPM to China along w/ an OEM iron head and giving the foundry the following instructions: 1. Make new head rook rike Ederbrock on inside 2. Make new head rook rike Chrysrer iron head on outside ![](/ubbthreads/images/graemlins/tonguue.gif) (My apology to all Asian and Asian-American readers who take offense to my accent parody. ![](/ubbthreads/images/graemlins/wave.gif) ) EDIT: Just re-read the orginal post and saw where the OP stated "One of them cracked where the early castings were prone to crack (end exhaust port into the spark plug hole, not really cost effective to repair)." ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: BradH]
#1455069
06/19/13 02:01 PM
06/19/13 02:01 PM
Posts: 3,363 DTW
drmopar
DTW
I bought a set of CNC'd stealth heads for my 451 I had in my last road runner vert and they still needed to be clearanced for pushrods. Just sayin.
If it were a racecar, Edelbrock heads. If it was a show car (FAST looks) then Stealth all the way.
-------------------- RM27H9G 4 speed F8/tan guts RS27L9G auto B5/black guts WM23H9G auto F5/green guts 2021 Challenger 392 Indigo/black guts 2019 Charger Daytona R/T F8 on black 2018 Ram Sport Hemi 4x4
[Re: Thumperdart]
#1455072
06/19/13 02:35 PM
06/19/13 02:35 PM
Triple Threat
Renton Washington
I don't understand the question here???... ![](/ubbthreads/images/graemlins/shruggy.gif)
Not to tough to figure out.....
Edelbrock heads=$1750, plus need to be checked for guide clearance and valve job
Stealth heads=$1000, plus need to be checked for guide clearance, valve job, and pushrod clearance
CNC Stealth=$2000, Ready to go, checked by Modern Cyl. Head
CNC Stealth is a no-brainer [/quote
You still end up with $2,000 worth of japanese crap..........
Unlikely they're made in Japan. Not all countries are the same, and there are chinese foundries that produce extremely high quality products, they're just not cheap so people don't use them.
If it was my Money RPM heads or the EZ head. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: JohnRR]
#1455074
06/19/13 02:51 PM
06/19/13 02:51 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Guess I'll go with bare Edelbrock heads... just noticed the aluminum "452" heads (good flow out of the box) but I think I'd rather screw around with angle plugs anyway
casting problems are scary, and hard to see
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: JohnRR]
#1455076
06/19/13 03:34 PM
06/19/13 03:34 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
\ Hope I don't get banned for this ....
Really John, that's just trolling there. That engine was hydraulic locked or the head bolts weren't torqued properly. Thumper- they are Chinese heads.... I bought the Eddie heads- the Stealths weren't on the market yet- and would recommend them, just because they are made in the USA. The Eddie heads are known to need setup work, no different than ANY aftermarket head- some of the MP stuff needs Major work. I'm having Brian @ IMM do a full setup and porting appropriate to my build. He's given me a very reasonable price and I like supporting a local shop. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: JohnRR]
#1455077
06/19/13 03:43 PM
06/19/13 03:43 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Holy crap! What's the story on that head?
[Re: VincentVega]
#1455078
06/19/13 04:04 PM
06/19/13 04:04 PM
Posts: 2,826 NY usa
540challenger
NY usa
IF i remember right the MP 452 head is cast by edelbrock and it is basiclly a RPM head with straight plugs
[Re: hudsonhornet7x]
#1455082
06/19/13 05:46 PM
06/19/13 05:46 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Been 10.07 @132 in a 68 GTX weighing 3600# race weight. Easy nines in a lighter car for sure. Cam could have been optimized as well, but this guy is a hardcore bracket racer, and didnt also want to deal with safety equipment running in the nines. He was running a 493 combo. They will work great from 440-512 C.I. All standard off the shelf stuff, not even ported intake etc...very user friendly.
RIP Monte Smith
[Re: JohnRR]
#1455086
06/19/13 05:59 PM
06/19/13 05:59 PM
I don't remember but when I saw it I right clicked SAVE ... the person that posted it up had more than one that was broken like that. I doubt they were hydro locked, this was a known issue with the early stealths, I hope for the sword swallowers sake that they don't have that issue anymore.
Dom, there is a huge difference between stuff made in Japan and the stuff made in China , Japanese stuff was on par with current china back in the 70's , much better today .
How fortunate for us that we have a world traveler that has his finger on the pulse of worldwide manufacturing quality Perhaps he can take a break from traveling someday, to actually finish one of the 3 engines he has been "building" for the last 10 years.... ...maybe then he can offer some first hand, REAL experiences... ![](/ubbthreads/images/graemlins/drive.gif)
