7 1/4 to 8 3/4 #145463
11/04/08 12:55 PM
11/04/08 12:55 PM
Missouri
Confusedcuda Offline OP
Missouri
Hi guys, I am going from a 7 1/4 to a 8 3/4 in my 67 barracuda. Can I use my 7 1/4 U-bolts or do I need to get new ones? Also I have a 904 tranny, does anybody know how much shorter my driveshaft will need to be? Is there a standard measurement or do I need to wait till I get the rear end installed and then measure. It is a 67 barracuda with a 904 that was a 273 now a 340, Thanks.
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145464
11/04/08 01:09 PM
11/04/08 01:09 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Yes, you need new U bolts and yes, you need a different drive shaft -- there is a 2.26" length difference between your tranny and rear you are going to have to make up just swapping the rear.
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145465
11/04/08 01:23 PM
11/04/08 01:23 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
You'll also need new bottom shock plates.
Re: 7 1/4 to 8 3/4 [Re: B5 Bee] #145466
11/04/08 01:29 PM
11/04/08 01:29 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
...and an e-brake cable
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145467
11/04/08 05:58 PM
11/04/08 05:58 PM
that's the best way, since there's always a stackup of tolerances that way its exactly where you would like it to be.
Re: 7 1/4 to 8 3/4 [Re: RangerDan440] #145468
11/04/08 06:01 PM
11/04/08 06:01 PM
Missouri
Missouri
Okay, the housing I am buying is supposed to have the perches on it and in the correct position. Is that what you mean by shock plates. I also have a place that will shorten my driveshaft, that should work,right. Thanks...
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145469
11/04/08 06:13 PM
11/04/08 06:13 PM
Is that what you mean by shock plates. Thanks...
the shock plates are the flat metal plates under the axle tubes on each end that the u bolts go down into & which the lower end of the shock(s) bolt to which as mentioned are different on the 8&3/4. My suggestion would be to get the 8&3/4 rear bolted in there,jack it up off the ground at the center of the 8&3/4 then butt the driveshaft all the way into the trans & measure how much needs to be taken off & add 3/4-1" to that figure.
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145470
11/04/08 06:18 PM
11/04/08 06:18 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
No, the perches are welded to the axle and they have holes that lock the axle onto the locator pins on the springs. Large u-bolts go over the axles and through the shock plates which bolt on under each spring.
Re: 7 1/4 to 8 3/4 [Re: Reggie] #145471
11/04/08 08:28 PM
11/04/08 08:28 PM
Missouri
Missouri
Okay, so it sounds like I need to get some 8 3/4 shock plates. Thanks for all the info. I will take some more if anyone has anymore.
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145472
11/04/08 08:30 PM
11/04/08 08:30 PM
Missouri
Missouri
If I butt the driveshaft all the way to the tranny, and then add 3/4'' to 1'' won't it be too long?
Re: 7 1/4 to 8 3/4 [Re: Confusedcuda] #145473
11/04/08 08:46 PM
11/04/08 08:46 PM
Motor City
68cuda27 Offline
68cuda27  Offline
Motor City
If you you butt the driveshaft all the way forward, you need to substract 3/4-1" from the dimension.
Good luck, I did the change from 7 1/4 to 8 3/4 earlier this summer. Make sure you use the vented bolt to attach the rear brake hose to the axle housing.
Re: 7 1/4 to 8 3/4 [Re: RapidRobert] #145474
11/04/08 09:45 PM
11/04/08 09:45 PM
[quote then butt the driveshaft all the way into the trans & measure how much needs to be taken off & add 3/4-1" to that figure.
if 2" needs to be taken off then add 3/4-1" to that figure so ie 2&3/4-3" needs to come off. At least that's what I thought I was saying but you got it.
Re: 7 1/4 to 8 3/4 [Re: RapidRobert] #145475
11/04/08 11:29 PM
11/04/08 11:29 PM
Missouri
Missouri
Thanks to all who replied. Excellent info..
