70 e body fasten seat belt light location for use w/mt #1454492
06/17/13 05:05 PM
06/17/13 05:05 PM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
hello
im asking for a customer who needs to install a seat belt warning light on a 70 e-body
does anyone know the correct location and does the manual transmission reverse light affect the location of it?
thanks
Re: 70 e body fasten seat belt light location for use w/mt [Re: TONY_DAGOSTINO] #1454493
06/17/13 05:46 PM
06/17/13 05:46 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Tony,
This might help.
Ola
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: 70 e body fasten seat belt light location for use w/mt [Re: cudaized] #1454494
06/17/13 06:11 PM
06/17/13 06:11 PM
DELAWARE
DELAWARE
hi Ola
thank you
thats the answer!
tony
Re: 70 e body fasten seat belt light location for use w/mt [Re: cudaized] #1454495
06/17/13 09:50 PM
06/17/13 09:50 PM
Ola,
Was that a manual trans option only thing or possibly a later model year thing? Our 70 chally vert doesn't have that.
Re: 70 e body fasten seat belt light location for use w/mt [Re: ] #1454496
06/17/13 10:38 PM
06/17/13 10:38 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
For option C15 - deluxe seat belts
Re: 70 e body fasten seat belt light location for use w/mt [Re: ] #1454497
06/18/13 12:19 AM
06/18/13 12:19 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Ola,
If your car was a three speed manual it would not have the reverse light. It is on four speed cars only.
Re: 70 e body fasten seat belt light location for use w/mt [Re: TONY_DAGOSTINO] #1454498
06/18/13 12:28 AM
06/18/13 12:28 AM
m46rat Offline
m46rat  Offline
hello
thanks
The reverse light location remains the same whether or not the car is equipped with the C15 seat belt option. If your customer is installing the seat belt light, in order to make things correct, he will need to also install a complete set of deluxe seat belts as well. Unlike regular belts, the webbing color will match the interior color. Also, they are incredibly hard to find! There are also four belt clips that will need to be found as well.
Re: 70 e body fasten seat belt light location for use w/mt [Re: TONY_DAGOSTINO] #1454499
07/09/13 03:10 PM
07/09/13 03:10 PM
DELAWARE
DELAWARE
the fasten seatbelt light in the same location as pictured if it wasn't a 4-speed car?
Re: 70 e body fasten seat belt light location for use w/mt [Re: m46rat] #1454500
07/09/13 09:55 PM
07/09/13 09:55 PM
PA
BS27ROB Offline
BS27ROB  Offline
PA
Dwight, the picture Ola provided is of my car. I don't know how or why but it has the seat belt light without C15. I have 2 Broadcast sheets and they are coded L73 S/BELT UNF LAMP but no C15. Any ideas?
Cy
