Opinions on rocker arm failure.
#1454013
06/16/13 09:01 PM
06/16/13 09:01 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Had a rocker arm failure last weekend, center three rockers on right side. Looks like they started to seize to the shaft and heated up and stretched and broke. All other rockers on that side and other side are ok. Checked cam lobes (solid cam), valves, coil bind and retainer clearance. Engine has good oil pressure and has oil to rockers on both sides when turning oil pump with drill. These are the older hughes/dove rockers. This engine has been together and running great for a few years. Not sure what caused the failure. Any ideas?
The only Carbs I care about are under the hood!
Re: Opinions on rocker arm failure.
[Re: bigtimeauto]
#1454020
06/16/13 10:06 PM
06/16/13 10:06 PM
Posts: 3,168 Wichita Kansas
B Dartman
Wichita Kansas
were the shafts on correctly?
x2; curious if oiling holes were installed upright thus preventing oil from lubricating the rockers.
Have also read that pretty much any set under $500 is prone to failure (cheap imports, cheap materials)
Sorry to see the carnage.
[Re: B Dartman]
#1454021
06/16/13 10:54 PM
06/16/13 10:54 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
how many passes on them? assuming they where correct they have a life span.. they stretch on the shaft..loose oil then fail
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Azzkikrcuda]
#1454022
06/16/13 11:03 PM
06/16/13 11:03 PM
Thumperdart
State of confusion
What brand are they...............
[Re: Thumperdart]
#1454025
06/17/13 12:50 AM
06/17/13 12:50 AM
Azzkikrcuda
North Dakota
These are the 1.6 ratio Dove/Hughes rockers. The shafts were installed correctly, that was the first thing I checked. This is mainly a street car that has only been down the track a few times.
[Re: Azzkikrcuda]
#1454030
06/17/13 09:08 AM
06/17/13 09:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
My opinion... if you notice they all started to blue(heat) on the adjuster side(load side) and in the one pic you can see smeared alum in the groove... myself I think the grooves cut and smeared the alum into the grooves and blocked off the oil... I have a set of similar type rockers but with no oil groove.. the groove takes away load area ... and if there is ANY edge on the shaft its gonna cut the rocker... JMO
[Re: Azzkikrcuda]
#1454032
06/17/13 09:24 AM
06/17/13 09:24 AM
MR_P_BODY
That is what I was thinking, the bannana groove cut into the rocker and started the damage. The car sits all winter and usually for a week or two between driving in the summer.
If there is a sharp edge it can cut.. needs a small radius on the grove if you want to use the grooved type
