Re: Opinions on rocker arm failure.
[Re: Azzkikrcuda]
#1454033
06/17/13 10:16 AM
06/17/13 10:16 AM
Posts: 2,177 ill
dennismopar73
ill
Had a rocker arm failure last weekend, center three rockers on right side. Looks like they started to seize to the shaft and heated up and stretched and broke. All other rockers on that side and other side are ok. Checked cam lobes (solid cam), valves, coil bind and retainer clearance. Engine has good oil pressure and has oil to rockers on both sides when turning oil pump with drill. These are the older hughes/dove rockers. This engine has been together and running great for a few years. Not sure what caused the failure. Any ideas?
Well the lack of oiling is the root cause! Whether it is from the shafts on upside down, or cam bearing turned has to be determaned ! It is hard to believe that a street car, that the squelling grinding noises this type of damage that is seen, was not heard ! not to mention the clattering of lifters early on! If what you say is true about the oiling on that side is still there, then those rocker shafts was installed upside down!! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: moparlifer]
#1454036
06/17/13 02:10 PM
06/17/13 02:10 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I have used Dove rockers without isssue, the aluminum alloy they use (7129) is stronger than what most manufacturers use.
I dont think the shafts were upside down(I bet the scuffing is not as severe on the opposing side of the shaft - cant see in pic) and if there were burrs left on the banana grooves, problems with changing valve lash ect would have been noticed soon after initial use.
I blame oil starvation. It does look as though the banana groove extends beyond the wear/scuff marks in several rocker locations that can be seen (not good) and I would be looking at this closely.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1454038
06/17/13 03:44 PM
06/17/13 03:44 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
The cam bearing is not turned, as it shoots a nice stream of oil out the feed hole in the head when you turn the oil pump over with a drill. The shaft was installed correctly. The grooves do extend beyond the bodies on most of the rockers.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#1454039
06/17/13 04:13 PM
06/17/13 04:13 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
did the end plugs on the shaft fall out ??
[Re: JohnRR]
#1454041
06/17/13 04:32 PM
06/17/13 04:32 PM
Posts: 3,397 Pa
Hot 340
Pa
That's a problem .
unless he uses hold-down blocks that the shafts fit through, and clearances were somewhat snug between each rocker set..
[Re: Hot 340]
#1454042
06/17/13 04:47 PM
06/17/13 04:47 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
That's a problem .
That is true , if he set it up it's .015ish clearance , but still that's enough to bleed off more oil there than if there were no grooves.
[Re: JohnRR]
#1454043
06/17/13 06:21 PM
06/17/13 06:21 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Man I have never seen rockers that jacked up before ![](/ubbthreads/images/graemlins/shock.gif) Possible over torque on the shafts causing less clearance between the rocker and shaft in certain areas ![](/ubbthreads/images/graemlins/shruggy.gif) Measure and see how round the shafts are at the mounting points. I just can't get over those rockers ![](/ubbthreads/images/graemlins/eeek.gif)
[Re: Azzkikrcuda]
#1454044
06/17/13 06:21 PM
06/17/13 06:21 PM
Posts: 2,177 ill
dennismopar73
ill
I will stick to my original statement! This type of damage only occures thru the lack of oiling issues! Either blockage, or incorrect install! and the amount of the damage that the issue had been ran awhile! Be that as it may the motor has to be torn down and completely gone through everything replaced! pay close attention to cam bearing install, and cleaning of oil passages!
[Re: dennismopar73]
#1454045
06/17/13 07:02 PM
06/17/13 07:02 PM
Posts: 3,168 Wichita Kansas
B Dartman
Wichita Kansas
I would be looking for all the aluminum,and where it went....pull the pan,if not engine to inspect,imho.
Agree. Unfortunately last summer I had a lifter on its way to failure (flat tappet with little to no load) and the bottom of the lifter became concave the associated cam lobe had begun to wear down too. Wear was minimal but took the approach mentioned above and ended up finding metallic residue from cam and lifter on the windage tray and scoring in the oil pump (that metal all has to go somewhere). Went ahead and turned a cam swap into an overhaul.
Hope you get it all sorted out and back in working order!
[Re: Azzkikrcuda]
#1454047
06/17/13 08:12 PM
06/17/13 08:12 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
how are the pushrods? looks like they cut the side of the rocker...
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: B Dartman]
#1454051
06/18/13 01:11 AM
06/18/13 01:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Hate to tell you but if you had metallic in the pan doent mean you needed a total rebuild... if you wipe out a cam the debris will fall to the pan... yes the pump will be trashed but the filter picks up the crap before it goes to the bearings... bearings are the first thing in line after the filter ![](/ubbthreads/images/graemlins/wave.gif)
[Re: loaderpro]
#1454052
06/18/13 09:21 AM
06/18/13 09:21 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
I say oil starvation as well, no disrespect but you say the shafts were on correct...meaning the oil holes were pointing down AND towards the exhaust manifolds?
![](/ubbthreads/images/graemlins/iagree.gif)
