360 HEADS SWITCH! #145398
11/03/08 11:49 PM
11/03/08 11:49 PM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
Ok you guys are probably sick of hearing me.i know im a kid and i probably get annoying.
I was told that adding 360 heads with the 1.88 valve i can just bolt on and go on my 1972 plymouth 318.Then i have been told it is a bad idea and a great idea.So i need to know the Pro's and Con's
what will it add and what will it take away?
thanks guys
i bow down to you
Re: 360 HEADS SWITCH! [Re: erick72] #145399
11/04/08 12:50 AM
11/04/08 12:50 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Me and my brother had a 1970 318 sitting around with 53,000 original miles, we picked up a set of 1991 360 heads (308 castings) from the boneyard and a 340 resto cam from Mopar performance. Bolted it all together with an old cast iron 360 4-bbl intake, 800cfm Thermoquad carb, headers and electonic ignition and put it in a short bed 1979 W-150 4x4 truck. We promptly wasted the transmission doing burnouts with 31-10.50 tires on the back.
Make sure your trans is in good shape prior to the swap.
Re: 360 HEADS SWITCH! [Re: erick72] #145400
11/04/08 12:57 AM
11/04/08 12:57 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You can do that and get a nice super low compression ratio and slow port velocity, great combo for a lower cubic inch engine to lose all tq at all. If you have ever driven a factory 4bbl 318 that had those heads you will see they are total dogs till they get reving and even then it don't make up for the lack of tq, the factory only did it for the emmision aspect. The only tim they will do you any good is with some way of brinngin the compression up a bunch plus running a cam that makes a 318 rev up pretty high.
Re: 360 HEADS SWITCH! [Re: 440fied] #145401
11/04/08 01:04 AM
11/04/08 01:04 AM
E
erick72 Offline OP
erick72  Offline OP
E
so thats the best combo.im gettin the trans rebuilt
Re: 360 HEADS SWITCH! [Re: HotRodDave] #145402
11/04/08 01:51 AM
11/04/08 01:51 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
done it a few times adn although the results are not optinum, the results are more power than you have at the present time. Milling the heads would help a great deal but you will get a definite kick in the pants without.
Re: 360 HEADS SWITCH! [Re: MoparforLife] #145403
11/04/08 02:20 AM
11/04/08 02:20 AM
E
erick72 Offline OP
erick72  Offline OP
E
ok so as in kick in the ants you mean stompin on the gas from a dead stop and gettin a little squeel?lol
or it will be bad?
so what does milling usually cost and if i don't do it i just won't gain any horse.right?or do i need to to really get a difference.
this is the main thing though
i literally just wanna buy a cheap dirty set to cleanup re do the valve seats and bolt on with no probs and add some horse.
so if i get 360 heads with the 302 casting date that should add some horse?
sorry i just wanna get this right.thanks
p.s what did the 302 casting heads come on?
Re: 360 HEADS SWITCH! [Re: erick72] #145404
11/04/08 02:31 AM
11/04/08 02:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
302 are close chamber 318 heads.
Tony
70 AARCuda Vitamin C
Re: 360 HEADS SWITCH! [Re: erick72] #145405
11/04/08 08:24 AM
11/04/08 08:24 AM
Upper Midwest
Upper Midwest
or it will be bad?
What it mean is yes you will have a gain with it that you will feel. Not as much as with the the heads milled to give you some more compression but none the less you will have a gain.
Don't just buy a used set of heads with out having them checked for cracks or some sort of guarentee that they are rebuildable.
Re: 360 HEADS SWITCH! [Re: MoparforLife] #145406
11/04/08 11:52 AM
11/04/08 11:52 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
In my example I don't think it was the best possible combination, but it was better than the 2-barrel intake and small port 318 heads that were on it.
The 340 resto cam is a pretty good cam, although there are some Comp cams we would have liked to have tried instead, but this motor was built with parts we had laying around.
The 308 casting 360 heads are an open chamber, and do have the small 318 exhaust ports, but they have the bigger 360 intake ports and the headers do help with exhaust flow.
If we had to try it all over again we might have used a set of 360 "J" heads with 2.02 valves, pocket port, gasket match to an Edelbrock air gap performer rpm intake and either comp cam XE268H or maybe XE274H, but at that point why not just build a 360, it's 42 cubic inches bigger to start with.
If you have a set of 360 heads with 1.88 valves and the heads are in good shape, I say go ahead and use them on your 318. Make sure you pick a cam, intake, and exhaust system that works well the heads though.
Re: 360 HEADS SWITCH! [Re: 440fied] #145407
11/04/08 12:57 PM
11/04/08 12:57 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
If you're gonna bolt and run tham anyway, why not go Magnums? They'll do better than the 302s, are more plentiful, and I would think will be cheaper. Patrick on here has a few sources for mild factory and Engine quest done sets cheap. You'll have to replace the lifters and pushrods too.. but that's not a big deal.
Re: 360 HEADS SWITCH! [Re: moper] #145408
11/04/08 01:29 PM
11/04/08 01:29 PM
NY usa
540challenger Offline
NY usa
Magnum heads would be the best choice.
They flow more then any other head in storck form.
The close chamber will increase compression.
The cost of the mag. head would be the same or close to any toher small block head. but when you factor in a different intake the correct lifters and pushrods for the oiling of th magnum heads you will be spending more.
If you have the money or time to save up some coin the magnum heads are a the best choice IMO.
Re: 360 HEADS SWITCH! [Re: 440fied] #145409
11/04/08 05:15 PM
11/04/08 05:15 PM
Upper Midwest
Upper Midwest
The 2.02 valves would be a waste. Even on a 340 or 360 they do not come into play until the higher RPM band is reached. In fact they can rob low end torque over the 1.88 valve head on a 340/360. On a 318 the effect would be worse yet. Some well versed machine shops told me this and I didn't believe it either till I took a set of 2.02 heads and made sure that the heads were cc'd the same and as close to equal specs as would very likely to be OEM. No other porting or machine work done. I gained absolutely nothing. Just as I was told would happen. Although they said that I could have gone the other way to but in my case I didn't. Use volocity rather than volume.
Re: 360 HEADS SWITCH! [Re: erick72] #145410
11/04/08 05:21 PM
11/04/08 05:21 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
302s were used on 2BBL civilian versions of 1985 and up Diplomats, Gran Furys and Fifth Avenues, but NOT on the 4BBL cop cars. They are closed chamber heads as mentiond and should give you a nice compression boost. I would go with Magnums if I had to choose though.
Re: 360 HEADS SWITCH! [Re: erick72] #145411
11/04/08 06:43 PM
11/04/08 06:43 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Get a 360 for a few hundred bucks and build that.
Leave the 318 stock to live another day moving your grocery getter around or get a set of 318 closed chamber swirl port heads and port them.
Then run a edelbrock performer intake, port matched.
Mopar performance engine book has a good little story about just what worked on there 318.
Re: 360 HEADS SWITCH! [Re: boydsdodge] #145412
11/04/08 07:43 PM
11/04/08 07:43 PM
E
erick72 Offline OP
erick72  Offline OP
E
so i should get 360 heads off a 19 what? 360.let me know what years
thanks guys
Re: 360 HEADS SWITCH! [Re: erick72] #145413
11/04/08 07:57 PM
11/04/08 07:57 PM
Upper Midwest
Upper Midwest
Any pre magnum head will flow about the same. Last 3 casting number - 915, 587, 596, 974. Some have rotators retainers on the exhaust valves. Ditch them and use regular length valve springs and regular retainers. Make sure to match the springs to your cam if you are switching cams.
Re: 360 HEADS SWITCH! [Re: 440fied] #145414
11/19/08 06:45 PM
11/19/08 06:45 PM
dougc426 Offline
dougc426  Offline
May i ask you what kind of vehicle the heads came out of?.Do the heads say 308 on them?.I have been looking for a set in the bone yard.Found some 302?Are they any good?Thanks...Doug
Re: 360 HEADS SWITCH! [Re: dougc426] #145415
11/19/08 06:56 PM
11/19/08 06:56 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
THESE ARE THE 915 "J" HEADS
Re: 360 HEADS SWITCH! [Re: Moparnut426] #145416
11/19/08 08:21 PM
11/19/08 08:21 PM
302's = better. magnums = much better. that way when you're done you'll for sure feel the difference and yes consider going with a 360. I believe any of the open chamber 360 70's heads(including 915's) will leave you dissapointed.
Re: 360 HEADS SWITCH! [Re: RapidRobert] #145417
11/19/08 08:27 PM
11/19/08 08:27 PM
central PA
mopartial Offline
mopartial  Offline
central PA
I'd love to, but dont Magnums take a different intake or need drilled to accept std LA intake?
If it aint broke, dont break it.
