Behind the grille blackout question? #1453805
06/16/13 02:39 PM
06/16/13 02:39 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
I've heard rumor but have no proof if Black or F8 (Dark Green) Cars came with the blackout treatment behind the grille??
A friend sent me pics of a Survivor F8 '71 Charger that has the blackout treatment.
The car in question is a '69 Coronet R/T (F8).
Was this a deal only on lighter color cars?
Thanks for the help!!!
Re: Behind the grille blackout question? [Re: wkroncke17] #1453806
06/16/13 02:50 PM
06/16/13 02:50 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
My '69 F8 RR had the blackout (St.Louis car). The exceptions to blackout that I've heard are black & dark blue (EE1 & maybe B7 cars). Anyone with those colors, post up and let's see if that was actually how it went down on the line.
Re: Behind the grille blackout question? [Re: topside] #1453807
06/16/13 02:55 PM
06/16/13 02:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My old 67 BelvedereII Hemi car was GG1 (Dark Green) and never had any blackout, also a St.Louis car.
Re: Behind the grille blackout question? [Re: ScottSmith_Harms] #1453808
06/16/13 03:04 PM
06/16/13 03:04 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
My 68 satellite, also gg1, had no blackout.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Behind the grille blackout question? [Re: Silver70] #1453809
06/16/13 03:21 PM
06/16/13 03:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have seen two original paint T/As, one black & one in dark green, both had the blackout.
Re: Behind the grille blackout question? [Re: wkroncke17] #1453810
06/16/13 03:39 PM
06/16/13 03:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
My 68 Charger that was dark Blue from the factory had the blackout. I think all cars should have had it and those that didnt were mistakes. Hate seeing restored bright colored cars without it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Behind the grille blackout question? [Re: HemiRick] #1453811
06/16/13 06:06 PM
06/16/13 06:06 PM
Wisconsin
Wisconsin
I agree - theres nothing like a Yellow car, and it sticks out through the grill like a sore thumb.
I have talked to some that say Black cars (For obvious reasons) didn't get it, the only other color was F8 (Dark Green).
Any pics of Survivor '68 or '69's?
Thanks all!
Re: Behind the grille blackout question? [Re: wkroncke17] #1453812
06/16/13 06:42 PM
06/16/13 06:42 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Anyone have a diagram showing where the exact locations the blackout went out to?
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Behind the grille blackout question? [Re: MoparJunkie] #1453813
06/16/13 06:50 PM
06/16/13 06:50 PM
Wisconsin
Wisconsin
Anyone ahve a diagram showing where the exact locations the blackout went out to?
If done factory correct, it is a sloppy process, and not an exact science.
On the assembly line a guy down in the pit sprayed it from the bottom of the car at an angle on the radiator support with no masking or exact placement of the black spray.
I'm sure there are alot of pics out there to go by.
Re: Behind the grille blackout question? [Re: wkroncke17] #1453814
06/16/13 06:58 PM
06/16/13 06:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The pit is actually a myth, lots of cars have blackout on top of the lower horizontal surface of the radiator yoke.
If the person spraying it was in a pit under the car, he would have needed a ladder or very long arms for that to happen.
Re: Behind the grille blackout question? [Re: Alaskan_TA] #1453815
06/16/13 08:53 PM
06/16/13 08:53 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
I have an F8 69 GTS that has the blackout.
Re: Behind the grille blackout question? [Re: rck850] #1453816
06/17/13 12:45 AM
06/17/13 12:45 AM
Wisconsin
Wisconsin
Hmmm....A survivor I assume?
Makes me think its only rumor that the darker colored cars did not get it??
Re: Behind the grille blackout question? [Re: wkroncke17] #1453817
06/17/13 09:32 AM
06/17/13 09:32 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
If you go by the Engineering drawing,
"OMIT BLACK-OUT PAINT . . . .
BLACK AY1TX9
MED DK BLUE MET AY2EB7
MED DK GREEN MT AY2EF8"
However if you have proof your car came with the treatment and was one of these colors I'd replace it. We all know assembly line treatments weren't flawless and for the guy spraying black-out on 90% of the cars, there seems to be supporting documentation that some in these colors received black-out due to habit or the gent not reading his shop order.
Re: Behind the grille blackout question? [Re: AAR#2] #1453818
06/17/13 10:38 AM
06/17/13 10:38 AM
Wisconsin
Wisconsin
BLACK AY1TX9
WOW!!
Thank you!
So now there is proof that these cars were not supposed to get it......BUT, if guys were in the habit of spraying every car, they probably just went ahead and did it!!
As far as I could tell, my Coronet (F8) did not have this treatment, and I'm not planning on putting it on now for sure.
Thank you so much!!
Re: Behind the grille blackout question? [Re: Alaskan_TA] #1453819
06/17/13 11:39 AM
06/17/13 11:39 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Well I'm glad that someone actually knows what they're talking about! I wish the rumor would stop about someone spraying the blackout in a pit-that was the undercoating line. Before he passed away, I spoke to a guy that worked in the St. Louis factory paint section between 67-71. He said they simply stuck their hand through the grille opening and sprayed as quickly as they could to get some black in there. He also explained that sometimes they just sprayed every car that came down the line-some guys would fill in the job temporarily and didn't know which cars got it & which cars didn't.
That would explain all the black paint on the top of the front valance-it would be absolutely impossible to get paint there if they were in the proverbial pit believed by many.
As a side note, I have many pictures of blackout on 69 F8 cars.
Re: Behind the grille blackout question? [Re: Paul Jacobs] #1453820
06/17/13 12:26 PM
06/17/13 12:26 PM
A collage of whims
A collage of whims
The pit theory is largely the result of the spray pattern. Looking at a 68-70 B-body lower tie bar, blackout's on the bottom & front, but not on the upper surface of the lip. Sticking a spray gun and its hose(s) through a grille opening would be difficult on some models, no? Perhaps the spray pattern & pressure was adjusted to blow through in a tight cone pattern, but I'd expect runs and thick "edges" with that.
I wouldn't expect the undercoat guy to do the blackout: a goof-up would be a real problem!
Hopefully, somebody somewhere has a photo of the blackout being applied, and this can be settled before it becomes a hostile argument.
Re: Behind the grille blackout question? [Re: topside] #1453821
06/17/13 02:16 PM
06/17/13 02:16 PM
Wisconsin
Wisconsin
We don't want anything hostile!!
I really appreciate all advice/comments - rumors whether they are true or false, it's still something I enjoy talking about.
I know this has been discussed here many times, and as I'm about to do my (F8) Coronet, I'd like to know what is correct whether I put it on there or not.
I'm leaning towards NOT putting it on there just for the fact that the paint really looks nice.
Thanks guys!!
Wally.
Re: Behind the grille blackout question? [Re: wkroncke17] #1453822
06/17/13 02:45 PM
06/17/13 02:45 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
After researching this using my admittedly "less than scientific" methods, I've come to the conclusion that there are a great many cars that weren't "supposed" to come with blackout that did....too many IMO to chalk it up to someone "filling in" or assy line mistakes.
The vast majority of F8 cars that I've seen have had the blackout. Possibly a plant thing or a change in procedure after a certain date, I don't know. What I do know is that if you have a Lynch Rd. '69 or '70 car in F8 there is a very good chance that it came with the blackout.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Behind the grille blackout question? [Re: Alaskan_TA] #1453823
06/17/13 03:33 PM
06/17/13 03:33 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
There was a picture in Mopar Action several years ago of a worker in the " pit" blacking out the radiator yoke. I seem to remember the picture being in E-berg's resto topic column. Anyone recall?
Re: Behind the grille blackout question? [Re: formula_s] #1453824
06/17/13 03:44 PM
06/17/13 03:44 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yes...
Seems to me I recall the car being yellow...
