lakewood bellhousing ? #145336
11/03/08 09:56 PM
11/03/08 09:56 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
i just got a used lakewood blow proof bellhousing for a big block do i need any adapters to run a 10.5" clutch, or will the starter bolt up as is? thanks
Re: lakewood bellhousing ? [Re: upnover] #145337
11/03/08 09:59 PM
11/03/08 09:59 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
As long as you still have the pilot for the starter pinion you are in good shape.
Gus
64 Plymouth Savoy
Dana 60
Re: lakewood bellhousing ? [Re: fourgearsavoy] #145338
11/03/08 10:04 PM
11/03/08 10:04 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
there are just 2 holes there, am i missing an actual bushing, or another piece? thanks again
Re: lakewood bellhousing ? [Re: upnover] #145339
11/03/08 10:27 PM
11/03/08 10:27 PM
Idaho
Runner Offline
Runner  Offline
Idaho
Re: lakewood bellhousing ? [Re: Runner] #145340
11/03/08 10:29 PM
11/03/08 10:29 PM
Rittman Ohio
Rittman Ohio
sounds like you neec this http://store.summitracing.com/partdetail...mp;autoview=sku
Yep thats it
64 Plymouth Savoy
Dana 60
Re: lakewood bellhousing ? [Re: fourgearsavoy] #145341
11/03/08 11:02 PM
11/03/08 11:02 PM
tulsa ok
U
upnover Offline OP
upnover  Offline OP
U
tulsa ok
thanks for all of the help, i will put that on the parts needed list, again i appreciate the help
Re: lakewood bellhousing ? [Re: upnover] #145342
11/04/08 12:09 AM
11/04/08 12:09 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Here is a pic with the pilot installed for reference.
Its in the 11" position. Move it closer for the 10.5" flywheel.
Re: lakewood bellhousing ? [Re: NTOLERANCE] #145343
11/04/08 12:14 AM
11/04/08 12:14 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I need to take a closer look at my Lakewood, I'm not sure what flywheel was used with it before.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: lakewood bellhousing ? [Re: AlexP] #145344
11/04/08 05:23 AM
11/04/08 05:23 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
I'm pretty sure I have one of those kits around here that I bought and didn't need. I can let you have for less then Summit if interested, let me know.
T.C.
