Sheetmetal Intake vs.Tunnelram #1452932
06/14/13 08:49 PM
06/14/13 08:49 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Is the cost of a Hogan Sheetmetal Intake worth it over buying lets say a Indy Tunnelram Intake.
What do you think the gains would be with a high dollar Hogan Sheetmetal intake vs. lets say a Indy cast aluminum tunnelram intake?
This will be going on a hemi with MP aluminum heads.
Re: Sheetmetal Intake vs.Tunnelram [Re: Sammy] #1452933
06/14/13 08:59 PM
06/14/13 08:59 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Sheet Metal intake, their only benefit is they are built to suit your particular engine. If the cast Tunnel ram was an exact match to your combination, the sheet metal intake would show no benefit.
Alan Jones
Re: Sheetmetal Intake vs.Tunnelram [Re: Sammy] #1452934
06/14/13 09:08 PM
06/14/13 09:08 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
INDY'S HEMI CAST TUNNEL LACKS A SUITABLE SIZE PLENUM .it is much too small . increases as much as 50 hp were gain when adding one inch spacer
home of the
Sox and Martin Hemi Duster
Re: Sheetmetal Intake vs.Tunnelram [Re: HEMIFRED] #1452935
06/14/13 10:41 PM
06/14/13 10:41 PM
nc
moeflo Offline
moeflo  Offline
nc
I don't doubt that. It's easier to add volume with spacers than to shrink it. Many SM intakes are done the same way to allow fine tuning the plenum to the specific engine.
Re: Sheetmetal Intake vs.Tunnelram [Re: moeflo] #1452936
06/15/13 05:42 PM
06/15/13 05:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The oldest TR were made too big on purpose - easier to install a stuffer than to add another gaskets and screws, change linkage, fuel lines, scoop position, throttle cable...
Boffin Emeritus
Re: Sheetmetal Intake vs.Tunnelram [Re: polyspheric] #1452937
06/15/13 05:47 PM
06/15/13 05:47 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I used the Indy tunnel-ram on mine with $350.00 worth of porting work done on it,and that might be the Best Bang for the $$$ also for you!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Sheetmetal Intake vs.Tunnelram [Re: Sammy] #1452938
06/17/13 12:11 PM
06/17/13 12:11 PM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
Weight and WOW factor are the main advantages and it is cheaper to build one off tunnel rams then cast them.
Also as stated earlier if built by some of the better intake builders.
they will build it to your engine spec and the rpm you want to run.
Re: Sheetmetal Intake vs.Tunnelram [Re: RADAMX] #1452939
06/17/13 08:52 PM
06/17/13 08:52 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Can someone post up a picture of a Indy Hemi Tunnelram.
I have no idea what they look like.
