MORE on the pilot bushing
The clutch kit is one that a buddy of mine bought sometime last year, and knew I needed one to get my truck back up and running. Yes it is borrowed, but hopefully it works. I needed one to get the truck moveable again. It sucks having a small driveway
So I got everything bolted together, was SURE the clutch was aligned, as the alignment tool was in and was TIGHT.
Went to put the trans in, and it would NOT go together. Tried rotating the shaft, moved the trans left/right/up/down, and it would NOT go together. Dropped the trans, felt the inside of the bushing and it was straight. I didn't mushroom it tapping it in, it didn't go in crooked, it didn't twist or anything else...Got tired of fighting it, so I ended up getting THIS bad boy
Pulled the NEW/OLD bushing out, cleaned the hole, and put it in. It's a pilot bearing from a 1996 ram 1500 manual truck
![](https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn1/1014387_10201276294050272_944973887_n.jpg)
Got the high torque starter installed
![](/ubbthreads/images/graemlins/biggrin.gif)
Starting to look like a 4 speed
![](/ubbthreads/images/graemlins/laugh.gif)
Still have a few things to do. It's lunch time haha, so I'll finish up later.
I still have the Zbar, linkage, driveshaft, and shifter to install. I need to put in the crossmember, but I need a new one. Payment sent, just waiting for hime to get it, and ship the crossmember
![](/ubbthreads/images/graemlins/punkrocka.gif)
