Need Help with a CUDA' #1452823
06/14/13 12:21 PM
06/14/13 12:21 PM
cumberland co. N.J.
BADDBOB Offline OP
BADDBOB  Offline OP
cumberland co. N.J.
I am installing a trans crossmember frame rail in a rotting 73 CUDA'.. Need a measurement for correct placement..Can someone with a cuda measure from the back of the torsion bar mount sleeve that is welded to your K-member..measureing to the front of the frame rail for the trans.. I am trying to make sure the trans mount lines up correctly..Thanks for any help
Re: Need Help with a CUDA' [Re: BADDBOB] #1452824
06/14/13 11:16 PM
06/14/13 11:16 PM
cumberland co. N.J.
BADDBOB Offline OP
BADDBOB  Offline OP
cumberland co. N.J.
no cuda's in the garage?
Re: Need Help with a CUDA' [Re: BADDBOB] #1452825
06/15/13 11:42 PM
06/15/13 11:42 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have a '72 I could measure for you tomorrow. Pm me your phone number and ill just call you and figure out exactly what measurement.
Re: Need Help with a CUDA' [Re: viperblue72] #1452826
06/16/13 09:05 AM
06/16/13 09:05 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
On my 73 this is measured from the face of the torsion bar cross member next to the bar socket. looks like 42-1/16" I would have to pull the control arm to be more accurate which I will be as soon as I finish my dollys.
Re: Need Help with a CUDA' [Re: T2R9] #1452827
06/17/13 10:10 PM
06/17/13 10:10 PM
cumberland co. N.J.
BADDBOB Offline OP
BADDBOB  Offline OP
cumberland co. N.J.
Thanks for the help..much appreciated
