Re: Exhaust bolts leaking coolant
[Re: Hotlumpy]
#1452533
06/13/13 08:46 PM
06/13/13 08:46 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
I leave all the studs that I can in place.But when I ran bolts I used silver antisieze.Never had any leak and they always came out.Rocky
Chrysler Firepower
[Re: Hotlumpy]
#1452534
06/13/13 10:22 PM
06/13/13 10:22 PM
RapidRobert
running OE shouldered studs is the best if they will let your header flange fit & can trim the outer fine threaded portion so there's only enough threads left for the nut to fit flush & any more threads is a waste & hampers fitment & can also get a high grade nut that is thinner so you can shorten the studs even more
[Re: therocks]
#1452535
06/13/13 10:23 PM
06/13/13 10:23 PM
Posts: 3,344 Central TX
roe
Central TX
I left studs in the water jackets and sealed them with blue permatex for waterpumps when I put the studs in about 2-3yrs ago. Just swapped over to headers, left studs in place. Still no leaks.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
