Page 1 of 3 1 2 3
Airwolf heads #1452293
06/13/13 04:29 PM
06/13/13 04:29 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Has anybody done some GOOD testing of these heads yet. Looking for some results on a good running combo.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: pittsburghracer] #1452294
06/13/13 09:12 PM
06/13/13 09:12 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Re: Airwolf heads [Re: pittsburghracer] #1452295
06/13/13 10:42 PM
06/13/13 10:42 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
dont know but was there last week and they are on back order. i guess the second batch has not came from china yet
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Airwolf heads [Re: WHITEDART] #1452296
06/13/13 10:52 PM
06/13/13 10:52 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think there was a magazine article that they tested some, but I can't remember where I seen it. Maybe you already know about that. Ill see if I can dig it up.
Re: Airwolf heads [Re: viperblue72] #1452297
06/13/13 10:56 PM
06/13/13 10:56 PM
PA.
"Little"John
"Little"John
PA.
Looking for track times in a well prepped 9 or 10 second combo.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: pittsburghracer] #1452298
06/13/13 11:49 PM
06/13/13 11:49 PM
V
viperblue72 Offline
viperblue72  Offline
V
Would this help? It seems like this engine would get you low 10s wouldn't it?
http://www.youtube.com/watch?v=_AfyrlVkEdk
Re: Airwolf heads [Re: viperblue72] #1452299
06/13/13 11:56 PM
06/13/13 11:56 PM
PA.
"Little"John
"Little"John
PA.
Saw that but I'm really looking for track times. Thanks.
I'm not a DYNO kinda guy. I like to see the track number.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: pittsburghracer] #1452300
06/14/13 12:13 AM
06/14/13 12:13 AM
V
viperblue72 Offline
viperblue72  Offline
V
I agree about track times.
Re: Airwolf heads [Re: viperblue72] #1452301
06/14/13 12:21 AM
06/14/13 12:21 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
You would think they should be 2 tenths or maybe a hair more better than well done eddies are... But until somebody throws a good car and combo under them to prove it, nobody knows.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Airwolf heads [Re: B3422W5] #1452302
06/14/13 12:35 AM
06/14/13 12:35 AM
PA.
"Little"John
"Little"John
PA.
Bingo. I know what i got out of my last set of Edelbrocks and where they started. to bad there not going on my car.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: pittsburghracer] #1452303
06/14/13 01:06 AM
06/14/13 01:06 AM
V
viperblue72 Offline
viperblue72  Offline
V
72 Dodge demon(his screen name) on here posted some times on a different thread. I think a 5.79 from a 6.01 with eddies and different camshaft. Maybe pm him.
Also Streetwize is using some and has ran them.
Re: Airwolf heads [Re: viperblue72] #1452304
06/14/13 10:43 AM
06/14/13 10:43 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
72 Dodge demon(his screen name) on here posted some times on a different thread. I think a 5.79 from a 6.01 with eddies and different camshaft . Maybe pm him.
Apples to oranges IMO.
Re: Airwolf heads [Re: justinp61] #1452305
06/14/13 11:01 AM
06/14/13 11:01 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Admittedly my set won't be a good example until I get my combo closer to optimized with a bigger (higher lift) cam and larger tube headers....and that may be a while. Built the Rocky as a play toy snd not as a test bed. Not often I do it but I 'wanted' the Airwolfs to be able to assess them, not that I 'needed' them.
I bought them in anticipation of a larger 440" small block underway, anf they wound up being a couple hundred more out of pocket over the Shady Dell stage 2's I had and sold. I bought Bryce's actual Engine Masters Dyno motor article set.
WIZE
In Car:
Re: Airwolf heads [Re: justinp61] #1452306
06/14/13 11:36 AM
06/14/13 11:36 AM
V
viperblue72 Offline
viperblue72  Offline
V
Very true. Will never know what just head swap would do.
Re: Airwolf heads [Re: viperblue72] #1452307
06/14/13 05:18 PM
06/14/13 05:18 PM
Kentucky
72 Dodge demon Offline
Kentucky
I don't have any apple or oranges but I like the the way the car runs. Haven't had any problems with them and everything bolted up. After the season is over I'll put in my old cam and find out.
Re: Airwolf heads [Re: 72 Dodge demon] #1452308
06/14/13 06:33 PM
06/14/13 06:33 PM
PA.
"Little"John
"Little"John
PA.
Do you mind listing your engine and car details.
As accurate as possible. weight, gearing, trans type, headers, conv stall.
engine specs. comp, gas, special ring pac, vacuum pump, carbs, intake, fuel octane, ect, ect.
THANKS.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Airwolf heads [Re: pittsburghracer] #1452309
06/14/13 06:46 PM
06/14/13 06:46 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
It's a Pro Comp Electronics Chinese copy of an Edelbrock head... it has powdered metal seats 9not great for life under hard use & big spring pressures) ultra cheap Pro Comp soft bronze guides....
& then They get CNC'd with a very large Edelbrock port program & it magically becomes an "airwolf" head....
Do they make power? I'm sure they do.... so do really big port Edelbrock heads....
Is the castings & parts of a lesser quality? Yep....
FULLY ported W2 is going to make more power than the CNC Airwolf head.....
Re: Airwolf heads [Re: domingo] #1452310
06/14/13 09:48 PM
06/14/13 09:48 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Have you considered running for office??
Fully ported W2's may make more power... and they weigh more, and they require offset rockers, and they require a new set of headers, and a new intake manifold.
The biggest advantage to edelbrocks over the airwolfs are, you can actually get them! 9 weeks as of now, waiting on a set of airwolfs, so if everyone is in the same boat I am, it's easy to understand why there aren't more on the track yet.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Airwolf heads [Re: domingo] #1452311
06/14/13 09:57 PM
06/14/13 09:57 PM
Washington
skrews Offline
skrews  Offline
Washington
According to Dr J's they come with ductile iron seats, and they install their own valve guides.
Re: Airwolf heads [Re: skrews] #1452312
06/15/13 04:25 AM
06/15/13 04:25 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
My heads have new ductile iron seats and guides that Bryce installed, I have no complaints at all with the quality and materials in my set of Airwolf heads.
WIZE
In Car:
Page 1 of 3 1 2 3
