Re: Need quieter air cleaner [Re: roe] #1452256
06/13/13 07:07 PM
06/13/13 07:07 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Getting tired of the constant air intake noise, all that air being sucked into the carb.. and the Waaaaaaaaaa sound when I open it up.
Man I never get tired of that. If I could get away with running no air cleaner at all I would.
Re: Need quieter air cleaner [Re: roe] #1452257
06/13/13 07:41 PM
06/13/13 07:41 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
look at a lil red express truck. there's a plan for fresh air ducting.
Re: Need quieter air cleaner [Re: BigBlockMopar] #1452258
06/13/13 08:04 PM
06/13/13 08:04 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think a stock snorkle aircleanerhousing with a K&N airfilter will flow the same/better, at a slightly cooler area, than that restrictive paper-airfilter sucking up all that underhood hot air rightabove that engine.
You do realize that independent testing shows that K&N doesn't necessarily flow best and it is no where near the best at keeping dirt out of your engine.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Don't be the exception.
Re: Need quieter air cleaner [Re: MileHighDart] #1452259
06/13/13 10:20 PM
06/13/13 10:20 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Brand X...
But you get the idea...
Re: Need quieter air cleaner [Re: roe] #1452260
06/13/13 10:52 PM
06/13/13 10:52 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
...just want it quieter for cruising with the wife.
You do understand that you then have to listen to everything she says right?
And, even answer her every question/remark/nag during that entire trip...!?
There might even be a chance you actually have to have an actual 'conversation' with her.
And don't even think you can get away with an occassional "Uh huh"-reply. You're toast if she catches you doing that.
I think I'd rather listen to that open airfilter roar for some 2-3 hours myself...
OK, you caught me, I was trying to blame it on the wife. But its mostly me. Just getting old I guess, don't like riding in loud cars as much as I used too...lol
And I'm assuming most of the time I'm out in the car, I'll be alone. But it would be nice to hear the radio.
Re: Need quieter air cleaner [Re: 440newport] #1452261
06/13/13 10:59 PM
06/13/13 10:59 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Man, I hear 'ya! I'm the first guy to bash on Thermoquads, but the TQ on my 71 Demon 340 sounds totally awesome at wide open throttle. Sounds even better than the 6 pack on the Road Runner.
Re: Need quieter air cleaner [Re: MileHighDart] #1452262
06/13/13 11:11 PM
06/13/13 11:11 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you have a hood pad and/or a rear hood to cowl seal?
Ummmm,, No and No
Well actually I have a hood pad but haven't installed it, and have the old cowl seal but didnt intall it after the paint job, figured i'd get a new one.
Does it ever smell a little like gas or exhaust fumes inside the car? The rear cowl seal will help prevent that.
Re: Need quieter air cleaner [Re: autoxcuda] #1452263
06/13/13 11:18 PM
06/13/13 11:18 PM
Central TX
roe Offline
roe  Offline
Central TX
Are those seals, hood to rad support, rear cowl, and under hood padding repro'd?
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Need quieter air cleaner [Re: roe] #1452264
06/13/13 11:30 PM
06/13/13 11:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
They are for 68 Darts.
I would think 71/72 Road runner would be the same for your car.
Re: Need quieter air cleaner [Re: autoxcuda] #1452265
06/14/13 01:11 AM
06/14/13 01:11 AM
Lyons, CO
Lyons, CO
Ummmm,, No and No
Sometimes, but much better since I got the new trunk seal installed. Was getting exhaust fumes comming in from the back.
But I get your point, I'll get those hood/cowl/rad support seals installed
Re: Need quieter air cleaner [Re: MileHighDart] #1452266
06/14/13 02:44 AM
06/14/13 02:44 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Ummmm,, No and No
A radiator hood seal will help with engine cooling.
Re: Need quieter air cleaner [Re: MileHighDart] #1452267
06/14/13 08:05 AM
06/14/13 08:05 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
What ever I go with, i'll probably keep the crome Edelbrock to put on at shows, and use the quieter air cleaner for everyday cruising.
Probably dont want to run any ducting,
The 1994-1995 full size vans
with Magnum 5.2/5.9 V8s
had round air cleaners
with sound cancelling design ( Helmholtz)
that would probably be quiet,
and can be run with or without the ducting.
The airboxes with duct to airhat design intakes
on Dakotas with Magnum v8s
would also be sound cancelling
and you could
"tune" the frequencies cancelled
by changing the length of duct
from airhat over to airbox
(longer = lower tone)
Re: Need quieter air cleaner [Re: MileHighDart] #1452268
06/14/13 10:52 AM
06/14/13 10:52 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
68-69 style gets my vote ... quiets the constant sucking sound, still get the WAAAH at greater increments of throttle ...
gotta get another one for my TQ, find a base ...
It takes gasoline to interest me.
Re: Need quieter air cleaner [Re: VL21] #1452269
06/17/13 02:08 AM
06/17/13 02:08 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
What does your car have for an exhaust system.
My loudest cars, on the intake side. Were from cars with manifolds and restrictive single exhaust cars.
Never knew why but after switching to headers and duals, all those cars became quiet on the intake side.
