Re: Need quieter air cleaner
[Re: roe]
#1452256
06/13/13 07:07 PM
06/13/13 07:07 PM
Posts: 4,588 St. John's Newfoundland
440newport
Getting tired of the constant air intake noise, all that air being sucked into the carb.. and the Waaaaaaaaaa sound when I open it up.
Man I never get tired of that. If I could get away with running no air cleaner at all I would.
[Re: roe]
#1452260
06/13/13 10:52 PM
06/13/13 10:52 PM
Posts: 7,798 Lyons, CO
MileHighDart
Lyons, CO
...just want it quieter for cruising with the wife.
You do understand that you then have to listen to everything she says right? And, even answer her every question/remark/nag during that entire trip...!? There might even be a chance you actually have to have an actual 'conversation' with her. And don't even think you can get away with an occassional "Uh huh"-reply. You're toast if she catches you doing that.
I think I'd rather listen to that open airfilter roar for some 2-3 hours myself...
OK, you caught me, I was trying to blame it on the wife. But its mostly me. Just getting old I guess, don't like riding in loud cars as much as I used too...lol And I'm assuming most of the time I'm out in the car, I'll be alone. But it would be nice to hear the radio.
[Re: 440newport]
#1452261
06/13/13 10:59 PM
06/13/13 10:59 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
Man, I hear 'ya! I'm the first guy to bash on Thermoquads, but the TQ on my 71 Demon 340 sounds totally awesome at wide open throttle. Sounds even better than the 6 pack on the Road Runner.
[Re: MileHighDart]
#1452262
06/13/13 11:11 PM
06/13/13 11:11 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
Do you have a hood pad and/or a rear hood to cowl seal?
Ummmm,, No and No
Well actually I have a hood pad but haven't installed it, and have the old cowl seal but didnt intall it after the paint job, figured i'd get a new one.
Does it ever smell a little like gas or exhaust fumes inside the car? The rear cowl seal will help prevent that.
[Re: autoxcuda]
#1452263
06/13/13 11:18 PM
06/13/13 11:18 PM
Posts: 3,344 Central TX
roe
Central TX
Are those seals, hood to rad support, rear cowl, and under hood padding repro'd?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: roe]
#1452264
06/13/13 11:30 PM
06/13/13 11:30 PM
autoxcuda
So Cal
They are for 68 Darts.
I would think 71/72 Road runner would be the same for your car.
[Re: autoxcuda]
#1452265
06/14/13 01:11 AM
06/14/13 01:11 AM
MileHighDart
Lyons, CO
Ummmm,, No and No
Sometimes, but much better since I got the new trunk seal installed. Was getting exhaust fumes comming in from the back. But I get your point, I'll get those hood/cowl/rad support seals installed
[Re: MileHighDart]
#1452266
06/14/13 02:44 AM
06/14/13 02:44 AM
autoxcuda
So Cal
Ummmm,, No and No
A radiator hood seal will help with engine cooling.
[Re: MileHighDart]
#1452267
06/14/13 08:05 AM
06/14/13 08:05 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
What ever I go with, i'll probably keep the crome Edelbrock to put on at shows, and use the quieter air cleaner for everyday cruising. Probably dont want to run any ducting,
The 1994-1995 full size vans with Magnum 5.2/5.9 V8s had round air cleaners with sound cancelling design ( Helmholtz) that would probably be quiet, and can be run with or without the ducting.
The airboxes with duct to airhat design intakes on Dakotas with Magnum v8s would also be sound cancelling and you could "tune" the frequencies cancelled by changing the length of duct from airhat over to airbox (longer = lower tone)
[Re: MileHighDart]
#1452268
06/14/13 10:52 AM
06/14/13 10:52 AM
Posts: 1,357 central Florida
VL21
central Florida
68-69 style gets my vote ... quiets the constant sucking sound, still get the WAAAH at greater increments of throttle ... gotta get another one for my TQ, find a base ...
It takes gasoline to interest me.
[Re: VL21]
#1452269
06/17/13 02:08 AM
06/17/13 02:08 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
What does your car have for an exhaust system.
My loudest cars, on the intake side. Were from cars with manifolds and restrictive single exhaust cars.
Never knew why but after switching to headers and duals, all those cars became quiet on the intake side.
