Bad lifter causing a miss? #1452027
06/13/13 12:07 AM
06/13/13 12:07 AM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
Anyone ever hear of a bad lifter causing a stock 440 to miss?
Re: Bad lifter causing a miss? [Re: moparcanuk] #1452028
06/13/13 12:26 AM
06/13/13 12:26 AM
More info what eng when does it miss (rpm/load) when did it start any parts changes preceding the onset etc. To ans your Q pull the plugs & do a compression test which'll tell you if a lifter issue is keeping the cyls from being filled properly/condition of the long block but I'd be inclined to think no
