Re: 383 Engine Question
[Re: Imrare]
#1451740
06/12/13 06:23 PM
06/12/13 06:23 PM
Posts: 2,141 junction city oregon
viperblue72
Don't think so. But you can still find factory 383 blocks without a problem. Nobody has a reason to raman a 383 block. Everybody wants more than that from an aftermarket block. That's like asking do they make an aftermarket 283 block. Now a low deck block with a big bore may be available through indy? But I think even then they didn't get enough sales and are discontinued? I could be wrong, but im pretty sure that's the case.
[Re: 383stude]
#1451744
06/12/13 06:38 PM
06/12/13 06:38 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Also there is nothing specific to a 383 from a roadrunner, in fact the only differentiation is between the 2 barrel and 4 barrel engines with the latter having the 4 barrel carb, more cam, and more compression. Even if you looked at 440s the only difference between the 440 in an Imperial and that of a 4 barrel roadrunner is the car surrounding the engine.
You are only partly right, you forgot the most IMPORTANT difference, the 2 stamps H and P .
The 383 HP also has different valve springs than a 2bbl engine , different exhasut manifolds, and the exhaust system is different and different setup of the distributor.
There wasn't a 440 installed in any roadrunner from the factory unless it had a 6pk induction ... EXCEPT for the 70 Superbird or it was a roadrunner with the GTX option.
[Re: Imrare]
#1451745
06/12/13 06:39 PM
06/12/13 06:39 PM
JohnRR
A gulag near you.
Okay, I guess I got the letters wrong? Maybe it was HP that I remember reading on the block...in any case, 69 roadrunners came with specific 383 engines...I am interested in purchasing a new block that is as close as possible to the OE specs of that engine...are they available?
There isn't a new block unless you get lucky and find an NOS block somewhere , but that block won't be stamped correctly.
I ASSuME you do not have the original engine for your roadrunner ?
[Re: JohnRR]
#1451746
06/12/13 06:44 PM
06/12/13 06:44 PM
Posts: 1,896 New England
Q5_Ed
New England
Surely you have an extra 383HP you can sell? If not there is a 69 383 forSALE IN B-BODY PARTS SECTION.
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
[Re: Imrare]
#1451748
06/12/13 07:04 PM
06/12/13 07:04 PM
JohnRR
A gulag near you.
As far as I know there is no cast iron low deck block available that looks the original 69 383 block. Yes you can buy a new lock deck block, Indy sells one and Keith Black sells one but they are both aluminum and I'm sure you could get them with a 4.25 bore if you wanted. I have seen your many posts on your overheating issues and without actually what you see as the issue it's hard to say what it is or isn't. Your other option is to find another 69 383 HP block and put your original in the corner. I helped a member deal with an overheating issue , it turned out there was a thin spot in the side of the block that was not allowing the cooling system to pressurize , it was found as a stain in the paint on the side of the block , ran a couple of bottles of Moroso ceramic seal thru the block and it fixed it.
[Re: JohnRR]
#1451749
06/12/13 07:48 PM
06/12/13 07:48 PM
Posts: 291 St. Louis
Imrare
St. Louis
JohnRR, yes we have had many posts over the years on this and like I said, I'm basically down to pulling the engine, the engine overheats at idle on a warm day. I've tried different thermostats, radiators, water pumps, timing, different gas, etc. etc. etc. nothing has helped. If the weather is cool 70 degrees or less, no problem, it can idle forever. but on a warm day, if the engine is warmed up, it will over heat to the point of spark knocking within 15 minutes. Rush hour traffic would be "killer".
Thanks for your information and ideas.
Bob
[Re: Imrare]
#1451750
06/13/13 08:59 AM
06/13/13 08:59 AM
Posts: 2,640 Nashville, TN
MOPARMIKE69
Nashville, TN
Bob
Did you use a fan shroud? You didn't mention one in your post. You must use a fan shroud on these. I have seen one solve MANY overheating situations on many cars. Especially at idle!
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Imrare]
#1451752
06/13/13 05:24 PM
06/13/13 05:24 PM
JohnRR
A gulag near you.
Yes, I used a fan shroud but the car is not coded for a fan shroud...it shouldn't need it.
Do you have a broadcast sheet ? the shroud isn't on the tag , but that aside the basic 3.23 geared runner and superbee in 69 didn't come with a shroud.
It'll be interesting to see what you find inside the block when you pull the core plugs.
I don't remember all the things that are pointing to it overheating, but does the system hold pressure when it's up to temp , is it boiling over ?
What are you using as a gauge to tell you the car is overheating ?
[Re: Imrare]
#1451755
06/14/13 09:49 PM
06/14/13 09:49 PM
JohnRR
A gulag near you.
I don't think you really have as big a problem as you think. Maybe the seller didn't mention it because it isn't a problem ? First off you can't fill the radiator to the neck, many people do that , guilty as charged , but that system does not have an overflow tank or a recovery system so it needs room to expand without burping out. Make sure you have the correct cap on it, a cap for a recovery system is going to allow fluid to escape because it thinks there is a tank on the end of the overflow hose. I'm sure that was already brought up. Now I'm going to ask the really STUPID question ... why are you letting it sit and idle till it overheats? What's your timing set at and what octane fuel are you running ? did you put steel shim gaskets back in or composite? When you took off the heads did you make note of the overbore size , if any? Here's a silly test for your idle adventure , put a fan in front of the car and see what happens . Also I wonder how hot it would get wit han original 190 degree thermostat in it ? I'm sure there is an OE unbuilt 383 block out there in an obsure warehouse or buried in the back of an engine shop somewhere. Do you have a 26" rad you could put in place of your 22" to see if the same problem with your extended idle till it overheats test? I had the same thing happen once with it overheating with an extended idle , 26" rad and a shroud, std bore 383 sitting in a line of traffic for 45 minutes. I didn't think about it while i was sitting in my truck and I do not know why my father sat there with it running for that long not going anywhere
