Re: Comp with eddy rpm's and L2355's
[Re: tuff440]
#1451643
06/12/13 12:05 PM
06/12/13 12:05 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
# of Cyl. 8 COMPETITION WEDGE Bore 4.3500 Stroke 3.7500 Rod Len. 6.760 Gskt Bore 4.410 Comp. Gskt .0390 Block Deck Ht. 10.7200 Top ring down 0.280 Chamb. Vol. 75.0 Dome (-) Dish (+)5.30 Piston / deck 0.019 Total volume 1009.37 Cylinder volume 913.28 Clearance volume96.09 Gasket volume 9.76 Top ring volume 1.40 Deck volume 4.63 Piston top land 4.305 1/2 Stroke 1.875 Comp. Ht. 2.066 Cubic Inches 445.85 Compression ratio 10.50
RIP Monte Smith
[Re: CompWedgeEngines]
#1451644
06/12/13 12:08 PM
06/12/13 12:08 PM
CompWedgeEngines
Syracuse,NY
Changed thew deck height on this one to match their listefd 2.061 C/H.
# of Cyl. 8 TODD @ COMP. WEDGE Bore 4.3500 Stroke 3.7500 Rod Len. 6.760 Gskt Bore 4.410 Comp. Gskt .0390 Block Deck Ht. 10.7150 Top ring down 0.280 Chamb. Vol. 84.0 Dome (-) Dish (+)5.30 Piston / deck 0.019 Total volume 1018.37 Cylinder volume 913.28 Clearance volume105.09 Gasket volume 9.76 Top ring volume 1.40 Deck volume 4.63 Piston top land 4.305 1/2 Stroke 1.875 Comp. Ht. 2.061 Cubic Inches 445.85 Compression ratio 9.69
RIP Monte Smith
[Re: viperblue72]
#1451649
06/12/13 09:53 PM
06/12/13 09:53 PM
Posts: 1,385 Ohio
rck850
Ohio
did they say when 75cc eddies would be available? I would guess they will be a hot seller just because of so many 440s having such low compression.
I was on hold while Summit Racing called Edelbrock just two weeks ago. I noticed the 75cc RPM's in their new catalog so I called. They told summit about one month and the guy at summit said give it about three months. This was for the Victor small block heads also.
[Re: rck850]
#1451650
06/12/13 10:14 PM
06/12/13 10:14 PM
CompWedgeEngines
Syracuse,NY
I sent a note to my Edelbrock rep today, so lets see what they have to say. Its very hard to pin them down regardless of what you hear.
RIP Monte Smith
