340 oil filter adapter info #1451364
06/11/13 04:49 PM
06/11/13 04:49 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I may have to pull a header to fix a leaking right angle oil filter adapter and don't want to have to do it twice. Just wondering whose gasket kit you guys would recommend.
Additionally what size is the bolt head? Thanks
Re: 340 oil filter adapter info [Re: UCUDANT] #1451365
06/11/13 05:08 PM
06/11/13 05:08 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'd use mine but that's just me
See out webpage for our full catalog and where to order (under Distributors)
http://www.superformanceproducts.com/
Re: 340 oil filter adapter info [Re: roadhazard] #1451366
06/12/13 12:32 AM
06/12/13 12:32 AM
Alberta, Canada
4004spd Offline
4004spd  Offline
Alberta, Canada
I just used a set of yours and can't say enough nice things about them. Thanks for making such good stuff!
Re: 340 oil filter adapter info [Re: roadhazard] #1451367
06/12/13 09:08 AM
06/12/13 09:08 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Roadhazard, when did you start making the adapter gasket set? When I did my 408 several years ago they were as rare as hens teeth. Thanks .
To the OP, Roadhazard may be your only source for the adapter gaskets. IIRC the bolt in the adapter is 1 1/8", I'll have to check.
Re: 340 oil filter adapter info [Re: 4004spd] #1451368
06/12/13 10:58 AM
06/12/13 10:58 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Well thank you!
Justinp61 I started putting these kits together about this time last year when someone was looking for them. Had all the stuff as it was used in our "Accessories Kit" aka Timing Cover Kit
I'm happy the quality stands out to you folks
