AFB vs AVS for Hemi #1451208
06/11/13 10:58 AM
06/11/13 10:58 AM
in a chair
mopartony Offline OP
in a chair
Guys I have a friend who is need of this info.
What are the pros and cons for running the AFB's or the AVS's.
Which are the best to run?
This is a very warm 496cid Hemi. It will have an inline 2x4.
Holley’s are a no go end of story.
All info is appreciated and good AFB and AVS carb builders is welcome too.
Re: AFB vs AVS for Hemi [Re: mopartony] #1451209
06/11/13 11:04 AM
06/11/13 11:04 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
AFB has weights that control the secondary opening
AVS has a spring loaded flap like a quadrajet or thermoquad
I prefer the AVS carbs and that is what I run on my car
Re: AFB vs AVS for Hemi [Re: mopartony] #1451210
06/11/13 11:11 AM
06/11/13 11:11 AM
New York
polyspheric Offline
polyspheric  Offline
New York
IMHO the AVS secondaries are both easier to adjust and to match F vs. R.
There's more tuning commentary for the AFB.
Boffin Emeritus
Re: AFB vs AVS for Hemi [Re: mopartony] #1451211
06/11/13 12:48 PM
06/11/13 12:48 PM
Delray beach, Florida
P
Performance Only Offline
P
I've built quite a few Hemi's with the inline 4 and the AFB carbs have always worked like a charm. Maybe it has something to do with the design of the intake?
machine shop owner and engine builder
Re: AFB vs AVS for Hemi [Re: mopartony] #1451212
06/11/13 01:18 PM
06/11/13 01:18 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
AVS's on a Stage V inline are the preferred street setup if originality isn't a concern. Either will work fine but I like the adjustable flap of the AVS. My current car is a 472 with a stock Hemi Convertor and 3.23 gears and it runs the best with stock rejetted AFB's and their progressive linkage however.
But if your friend has a bit of gear and some convertor the AVS's on the Stage V will work great.
Sheldon
Re: AFB vs AVS for Hemi [Re: RUNCHARGER] #1451213
06/11/13 01:52 PM
06/11/13 01:52 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
dual avs 800s are said to work great on a stage V dual carb intake...
dual AFBs is what came on from the factory.....so I guess that would be the choice if you are running a stock intake??? The fast guys use a stock vanke ported intake also use AFBs
Re: AFB vs AVS for Hemi [Re: sixpackgut] #1451214
06/11/13 02:13 PM
06/11/13 02:13 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
X2
Re: AFB vs AVS for Hemi [Re: domingo] #1451215
06/11/13 02:15 PM
06/11/13 02:15 PM
dogdays Offline
dogdays  Offline
AFB, AVS, really quite similar. The AVS has a tunable air valve secondary, the AFB is an earlier version and doesn't. So if you want to tune secondary opening on an AFB it's more work.
I'd say two Edelbrock Thunder series or two of the new Street Demon with the black plastic float bowls.
R.
Re: AFB vs AVS for Hemi [Re: dogdays] #1451216
06/11/13 02:28 PM
06/11/13 02:28 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Is this for a NSS set-up? if so I would give these guys a call Diamondback
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: AFB vs AVS for Hemi [Re: mopartony] #1451217
06/11/13 02:35 PM
06/11/13 02:35 PM
All the stock street Hemi intake manifolds came with the AFB bolt patterns, the AVS are the same bolt pattern as the 4150 Holleys. You can drill the base of the AVS to change them to fit the AFB manifolds and pattern Large motors, especially 426 type Hemiroids, like lots of air
Re: AFB vs AVS for Hemi [Re: Cab_Burge] #1451218
06/11/13 02:42 PM
06/11/13 02:42 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
I use AFB'S on mine
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: AFB vs AVS for Hemi [Re: BB65Barracuda] #1451219
06/11/13 04:36 PM
06/11/13 04:36 PM
in a chair
in a chair
Thanks guys.
What about tuning parts? are those available?
This car has full exhaust and is strictly street use. No track time to speak of.
Go out drive and have fun, lots of fun but fun none the less.
Re: AFB vs AVS for Hemi [Re: mopartony] #1451220
06/12/13 01:39 AM
06/12/13 01:39 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I had two 600 Eddy AFB's on my 434 hemi (Stage 5 intake) & after switching my cam to a solid Bullet, I switched to 650 Thunders, which were easier to tune & gave excellent throttle response. Both bolted right onto the Stage 5 intake & fit the Shaker baseplate. Hard to judge if the 650's outperformed the AFB's since I changed the cam & rebuilt the Hemi, but the Thunders sure had great response.
Re: AFB vs AVS for Hemi [Re: Triggerfish] #1451221
06/12/13 07:35 AM
06/12/13 07:35 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I run two stock 750 eddy AFBs on my 572 wedge. Chokes removed and secondarys jetted up, no other mods. Even with a 285@.050 cam it idles great, good throttle response. Its gone 9.30@144 .
Doug
Re: AFB vs AVS for Hemi [Re: torkrules] #1451222
06/12/13 07:45 AM
06/12/13 07:45 AM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
X2
x3
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
