1968 Hemi Dart K spacers #1450847
06/10/13 08:54 PM
06/10/13 08:54 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
What are the advantages and disadvantages in using the 1/2" spacers used between the K member and frame? Also is it worthwhile to move the steering gearbox closer to the frame to give a little more room between the steering shaft and the head/valve cover? I found it is a little close in the rear corner where the steering shaft exits the firewall. The steering outer tube has been cut back to clear the head already. I found by putting in the 1/2" spacers it moves the head from above to below the steering shaft. Either way it's close. The engine is placed in the dimensions given by tti.
Re: 1968 Hemi Dart K spacers [Re: maximus] #1450848
06/10/13 08:58 PM
06/10/13 08:58 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Well they were used so the Hemi would fit in the A-Body's, I don't know of any advantages or disadvantages, only the reason they were used. There were other changes like the bump-stops on the control arms, hammering the inner fenderwells, and master cylinder offset block.
JB Rhinehart, Realist
A-Body's RULE!
