Can someone ID this carb? #1450501
06/10/13 01:35 PM
06/10/13 01:35 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
I believe it's the original to my 68 383/4 speed charger - want to rebuilt it but I'm not sure who made it.
PN on base appears to be E8-44266 or 4426S
Re: Can someone ID this carb? [Re: MOPAULY] #1450502
06/10/13 02:06 PM
06/10/13 02:06 PM
dogdays Offline
dogdays  Offline
Carter AVS
4426 S
1968 383HP
R.
Re: Can someone ID this carb? [Re: dogdays] #1450503
06/10/13 02:30 PM
06/10/13 02:30 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
with a May 1968 assembly date
Re: Can someone ID this carb? [Re: ScottSmith_Harms] #1450504
06/10/13 03:03 PM
06/10/13 03:03 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
thanks guys - it came up after I searched on the S instead of the 6. I found a place in WA for a rebuild kit, anyone else sell them?
Re: Can someone ID this carb? [Re: MOPAULY] #1450505
06/10/13 03:17 PM
06/10/13 03:17 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can get it from NAPA !
Re: Can someone ID this carb? [Re: 62maxwgn] #1450506
06/10/13 03:20 PM
06/10/13 03:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yep standard kit , 446B I think ...
Re: Can someone ID this carb? [Re: 62maxwgn] #1450507
06/10/13 03:23 PM
06/10/13 03:23 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
wow, I just checked, no sh-it you really can $30
